civic 04 ATF fluid
Old May 21, 2009
dhkimboa's Avatar
dhkimboa is an unknown quantity at this point
civic 04 ATF fluid
hello i need to change the ATF fluid which i believe it's the automatic transmission fluid. What oil should i use for it? can I do it myself? Keep in mind that I live in mexico so some brands of fluids I might not get down here ty
Old May 21, 2009
CraigW's Avatar
Re: civic 04 ATF fluid
Only Honda ATF-Z1
Old May 21, 2009
ya honda fluid and a 3/8 ratchet are all you need. loosen bolt, let fluid drain, tighten bolt, add about 3 qts fluid from dipstick hole, drive car around its it warmed up, and check the level to be sure its full. if car isnt lowered, usually you can squeeze under there without lifting the car on jackstands.the drain plug has a square key and is somewhere on the passenger side of the engine bay under the car.
Old May 22, 2009
dhkimboa's Avatar
hello guys for your answers
do i have to go to honda's agency to get the fluid? or can i get it at somewhere else?
is this a ratchet? http://en.wikipedia.org/wiki/Ratchet_(device)
Old May 22, 2009
04 Honda Civic's Avatar
u dont know what a regular ratchet is? The one that u put sockets on..not the big or the small one the one in the middle lol 3/8. Only Honda sells honda fluid. Auto stores do not sell it.
Old May 22, 2009
dhkimboa's Avatar
may be I just dont know the word in english
so i guess i'll have to go to honda's for that fluid ^^
so no synthetic fluid for it?
Old May 22, 2009
http://alloy-artifacts.com/Photos/to..._w560_h298.jpg
ah I didnt know english wasnt your first language..thats a ratchet.
Just use Honda ATF I wouldnt risk anything else and its not crazy expensive. U only need 3 quarts.
Old May 22, 2009
i guess its also called 'socket wrench' lol. except you dont need the sockets, just the wrench with square tip. 3/8 inch. actually you may also need a cheater pipe because usually the bolt is stuck pretty good. just get a straight exhaust pipe a couple feet long that you can put on end of the wrench so you have a longer handle with more leverage.
Old May 23, 2009
dhkimboa's Avatar
that was what you meant O_O a wrench *_* i didn't know they were called ratchet as well
yeah... english it's my third language hehe
ty for your advice guys!! it was pretty much helpful!! I'll go on Monday to buy some H ATF I for my AT ty ty guys!
Old May 23, 2009
its Honda not H lol I miss typed
Old May 23, 2009
dhkimboa's Avatar
hahahahah damm thought that was weird xdddd ty for your help guys!
Old Jun 1, 2009
dhkimboa's Avatar
how much does it cost in usa? cause i took the car on Saturday and they called me today along with other things they're gonna do to the car
just for the fluid it's gonna be like 65 bucks O_O I think it was only the steering fluid
Old Jun 1, 2009
umm around $6-7 a quart. But you only need 3 so its really not that expensive $65 USD is crazy for 3 quarts of tranny oil..at that price they should be including the labor as well..maybe you misunderstood them?
Old Jun 1, 2009
dhkimboa's Avatar
guess so i went there and checked it wasnt that expensive but those ****ers charged me for 40.000 kms service ? 2 months ago i did the 70.000 kms service... I will call them tomorrow WOW....
Old Jun 2, 2009
i had to buy one bottle to top off moms trans, the bottle is $8 now!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
Richkid23
Apr 19, 2015 12:53 PM
