Timing belt at 76K for 2000 civic? - Honda Civic Forum
Old 03-17-2009
bgrk is an unknown quantity at this point
I have a 2000 Civic LX which has done 75k miles. I was told by the dealer to have my timing belt replaced as it is more than 7 years, even though mileage is less. Should I replace it now or wait for 105k miles? It is pretty expensive at the dealership, at around $500. At the same time, if it is a must do now, I can think about it. Any suggestions are welcome.
bgrk is offline
Old 03-17-2009
04 Honda Civic's Avatar
Re: Timing belt at 76K for 2000 civic?
I say go for it, I find alot of people change it at 80k even before 7 years. $500 for parts and labor isnt too bad
04 Honda Civic is offline
Old 03-17-2009
well the newer 01+ civics say 10 yrs or 100k miles, so idk. maybe wait a few more years? it mostly depends on the climate. if you live in humid area where there isnt alot of severe hot/cold, you should be fine for 10 yrs. also you might be able to peek at the belt from under the car to see what condition its in.
gearbox is offline
Old 03-17-2009
sl33pyriceboi's Avatar
yes you should replace it. its better safe then sorry.
if ur timing belt snaps....u gotta rebuid ur engine, and that willl cost you thousands...
sl33pyriceboi is offline
Old 03-17-2009
here is an explanation/example:
http://www.youtube.com/watch?v=DGh-3fvK61I
Old 03-17-2009
97EK's Avatar
97EK will become famous soon enough
I'd do it. I had mine done a few months ago and my car only had about 67,000 miles at the time. However, it's a 97, so 11 years is quite a bit of time. I just hit 72,000 miles this week.
97EK is offline
Old 03-17-2009
when you replace ur timing belt, it is also smart to replace:
water pump, belt tensioner, power steering belt, AC belt, and soem gaskets and seals
they are all in the same area, so you should replace those as well...
you should be spending somewhere aorund 400 bucks for the total job. thats how much it is, and its a the BIG maintenance you do for ur car.
Old 03-17-2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
had one hop a couple teeth on my 99 prelude with 60 thousand on it and 6 years after six years the belts tend to go regardless of the mileage. and $500 is cheap for timing belt if you have the dealership do it they usually charge at least $700 if not a $1000. Honda also charges a thousand just to pull the head if it goes. look at about $3500 from honda if you loose the belt.
bomerman19 is offline
Old 03-17-2009
97EK's Avatar
Exactly. Get it all done, and you'll be good for a long while.
Just a heads-up though. The dealer is probably gonna charge anywhere from 700-1200 for all of that (maybe more). You could go with other shops or mechanics, but make sure they're reputable and know what they're doing lol.
97EK is offline
Old 03-18-2009
sql_civic's Avatar
DO it yourself. It's not hard.
sql_civic is offline
Old 03-18-2009
Ricky Bobby style, IWGF
02civic21's Avatar
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
i got a mobile/shade tree mechanic with air compressor on his truck to come do mine for 150. screw 500 at the stealership
02civic21 is offline
Old 03-18-2009
no, stealership is 600-1200
any good and reputable mech shop will do it for 400ish with all the corect parts.
150 sounds like he didnt do much except for changing ur timing belt.
timing belt, power steering belt, AC belt, tensioner, water pump, gaskets, seals alone cost more than 150. oem or aftermarket.
mattdoc
03-14-2017 01:10 PM
MN-02-CivicEx
28
05-02-2015 10:11 PM
rcolosi
04-29-2015 08:48 PM
dano2005
7th Generation Civic
04-14-2015 02:58 AM
Gunner
10-06-2012 01:37 PM
Quick Reply: Timing belt at 76K for 2000 civic?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
