How much Lucas oil?
Old Oct 10, 2007
def01tones's Avatar
You bought a used dog??
def01tones will become famous soon enough
How much Lucas oil?
I bought a quart of Lucas oil stabalizer cuz I hear its good **** from alot of people. Question is how much do I use? I was told to use the whole quart wit 3 of oil? Or just alittle Lucas with 4 of oil? The directions on the bottle don't make sense to me. haha
Old Oct 10, 2007
jrock's Avatar
jrock will become famous soon enoughjrock will become famous soon enough
Re: How much Lucas oil?
you replace a quart of oil with the lucas....I used to use it, I stopped putting additives in my engine.
Old Oct 10, 2007
def01tones's Avatar
would u recomend it? What ur opinions on it?
Old Oct 10, 2007
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
i have heard good and bad... supposed to cause foam in the oil or something like that which is bad... there is supposed to be a better alternative... just search for oil additives or stabilizers you should find it
Old Oct 10, 2007
sl33pyriceboi's Avatar
most members on her including gearbox and i use LC20 and FP60...they are awesome stuff that actually works...
search the forums and you'll see.
i have the code that givs you teh gallon ones for like 25bucks...ill find it if u really want it.
Old Oct 10, 2007
def01tones's Avatar
we could all use the code. Gimme gimme gimme!
Old Oct 10, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
yeah man I wouldn't mind the discount, I do my own oil so i would get the use out of it
Old Oct 10, 2007
lmao i would never use it. lubecontrol stuff ftw! and discount codes are gone, they actually have a new fp60 called fp+ which im ordering soon. ill stick with the stuff that actually works without messing up the car.
Old Oct 11, 2007
actually gearbox, i saved them...and u can actually search and find it. its one of YOUR (gearbox) post actually...
and yes they work because i just did it and it went through.
"lc20galrtn05" = to buy the LC20
"fp60galrtn05" = to buy the FP60
^those are the gallon ones.
they cost 26.50 bucks each.
NOTE TO EVERYONE: you use the FP60 2x as fast as the LC20. when i finished my bottle of FP60, i still had about half my LC20 left.
REP +1 for meeeeeeeeeee
Old Oct 11, 2007
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
where are you guys buying this stuff from? online or local shops? thanks!!
Old Oct 11, 2007
www.lubecontrol.com
and i meant no coupon for the fp+ which is around $50 a gallon. but its worth it cause you only use 1oz per 10 gallons which will make it last as long as 2 gallons of the old stuff.
Old Oct 11, 2007
thanks Gearbox!
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
stvpagn
Jul 9, 2015 09:59 PM
