Advice on 150,000 checkup
Old 05-08-2008
laney619's Avatar
laney619 is an unknown quantity at this point
I just hit 150,000 miles and I'm not sure exactly what I should get done, checkup-wise. I want it to last at least another 50,000 miles - any advice on maintenance I can get that will keep the car going?
Thanks in advance!
Old 05-08-2008
Re: Advice on 150,000 checkup
well nothing is really related to that mileage. everything should be done on a need-to-do basis. brake fluid every 3 yrs, coolant every 3-5 yrs, trans fluid every 30k or sooner, timing belt every 90k, brake pads/rotors when needed, valve adjustment every 100k or when needed, plugs when needed, oil when needed, air filter, etc. but other than the obvious, just check around to make sure major parts are working like intake, header, exhaust, cat, suspension components like bushings and tie rods and sway bar links, stuff like that.
Old 05-08-2008
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
^ thats about all I would do. They run forever as long as you take care of them
Old 05-09-2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
i heard that some vehicle manufacturers suggest doing valve adjustments every 30k miles. if you know how to do it yourself thats what i would do.... it isnt very difficult and it will make your car run a lot better. all you need for a valve adjustment are some feeler gauges, a 19mm socket, a 10mm wrench and a screwdriver. if you havent yet check the valve adjustments!
Old 05-09-2008
CiViCPrAnInG2k1's Avatar
damn... that's a lot of mileage...
SammySC
121
04-07-2017 07:43 PM
2002ExCivic
22
09-28-2015 08:29 AM
PunX
09-23-2015 10:45 PM
sf3r8z
09-23-2015 03:26 PM
bhollie
09-22-2015 11:08 PM
Quick Reply: Advice on 150,000 checkup
