Honda Oil Question
Rep Power: 0 Honda Oil Question
Just a question. I noticed that around here my dealer charges pretty much the same for an oil change that a random lube shop does. I used to do my own oil changes but I don't have a garage to do them in anymore so I have to pay someone to do it. I know that when I go to the dealer, they will use the Honda oil that god knows who makes. Is that oil any good or should I keep taking it to lube shops that use Castrol or Mobil 1, etc?
Rep Power: 787 Re: Honda Oil Question
its okay, i personally would not use it because there are much better oils for about the same or cheaper price. honda oil = regular mobil1 non synthetic.
04 honda civic beat me to it lol^
same here, coolant you might possibly get away with using xerex import coolant, which is pretty much the same as the honda stuff as far as the basics (no silicates, has phosphates), but who knows about the rest like corrosion inhibitors, pH, and lubricants. PS fluid is so cheap you might as well use the honda stuff anyways.
Rep Power: 0 Re: Honda Oil Question
Honda oil is NOT Mobil "1" it's "Mobil" oil... Mobil 1 is the full synthetic, and that's not what Honda oil is. Honda oil is blended by XOM which is Exxon Mobil. Don't get the Mobil 1 and Honda oil mix up.
There's Mobil Clean 5000, high mileage, 7500... Then there's Mobil 1 and Mobil 1 Extended Performance. It's either Mobil Clean (non synthetic) or Mobil 1 (synthetic)
https://www.mobiloil.com/USA-English...Oils/Oils.aspx
You know there's no such thing as Mobil 1 non synthetic right?
0w20 is really thin and wont provide adequate protection during the summer. i would only recommend using it for hybrids in the winter if you must. ive even had problems with 5w20 in the summer on my regular civic, so now i only use 5w30 and never had any more issues. with 5w20, my rear main seal was leaking and the engine light came on for vtec problems. switching to 5w30 seems to have fixed the leak (i dont see any oil on the ground, altho there is some sweating on the engine), and no more engine lights. car also seems to run better.
jessicakaybby
04-20-2015 12:11 PM
Unleaded
06-26-2007 09:25 PM
Bartkat
20
02-19-2002 01:29 PM
civiccowboy
11-19-2001 03:44 PM
