About to change my ATF and i have 3 Qs
Old Aug 14, 2007
K.Low's Avatar
K.Low is an unknown quantity at this point
Should the car be leveled or can i just jack the front of the car ???
Should i buy 3 or 4 qrts ???
Should the fluid be warm ???
Old Aug 14, 2007
Re: About to change my ATF and i have 3 Qs
5 qts (better to have extra if something happens), wait til car is cold, then change. no need to jack car unless you cant fit under it. once you finish, need to carefully drive the car around til it warms up, then check the level with car running and bring it to the max mark on the dipstick.
Old Aug 14, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
nothing like hot tranny fluid all over you (if you were thinking nasty things, stfu, thanks! ;-) )....exactly what gear said. I am not sure if our pans come with plugs in them but i would put one in the pan if it doesnt because I remember doing the tranny fluid on my 90 Lincoln town car an getting that **** all over the place when I took the pan off. It was to be expected, but what can ya do?
Old Aug 14, 2007
we have a drain bolt that you take out, but the fluid flows out pretty slow. you have to leave and come back 10 mins later.
Old Aug 14, 2007
ryox82's Avatar
that is def comforting lol. I will probably end up doing my own since that is the case.
Old Aug 14, 2007
d0ughbOy81's Avatar
d0ughbOy81 is an unknown quantity at this point
when i worked at honda i know that our cars took like 3.5-4 qts but this is how i did it (i still get to use the lift there soo its easy for me)
1 drain it ull need a 3/4 rachet for the drain bolt
2 after its done replace the drain bolt with a new washer
3 let the car down add 2.9 qts ull need a long funel to do so
4 start it while foot is on the brake run it to all the gears like 5 sec each
5 drive it around the block then check level and add if u need some more
p.s. i found this out the hard way if u take out the dip stick b4 u drain it will drain faster
**********but if u have a lot of miles on that tranny and its never been done i would not mess with it cuz u will **** up ur trans****************
Old Aug 14, 2007
ya i heard that, like the new fluid will cause chunks of crap to come loose and clog the filter. with just a drain and refill tho, you are barely changing 1/3 of the fluid. i think theres over 9 quarts in the whole system like torque converter and cooler lines.
Old Aug 15, 2007
K.Low's Avatar
My car has 39k miles...i dont think the ATF fluid has ever been changed.
Do you think its gonna be a problem ???
What if i refill it 3x ???
Thanks guys !
Old Aug 15, 2007
thats fine, 30k miles is the recommended interval altho i prefer yearly. but were talking like 100k+ miles on the original fluid.
Old Aug 15, 2007
K.Low's Avatar
so its ok to flush the whole tranny ?
Thanks
Old Aug 15, 2007
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
Thanks
you dont need to flush it...only drain and fill...
do another drain and refill only if you think there is no improvement..
Old Aug 15, 2007
dont do a flush, thats not good at all on any trans. just drain and refill. you can do it a couple times too if you want. like do one drain and fill, drive it around, do it again, etc. until the mixed fluid looks red again instead of black.
Old Aug 15, 2007
K.Low's Avatar
Ok thanks guys !!
Old Aug 15, 2007
K.Low's Avatar
One more question what happens if i overfill it ???
Old Aug 15, 2007
ryox82's Avatar
Drain some of it. You dont want to create too much pressure
Old Aug 15, 2007
yea overfill = very bad. dont overfill or youre have to take the drain bolt off again to remove some.
chuffsy
May 16, 2015 03:52 PM
BootyDo
May 7, 2015 04:46 PM
markp94
Apr 30, 2015 09:19 PM
Herman49
Apr 29, 2015 01:22 PM
silverdevil
20
Jun 2, 2007 04:42 PM
