PDA
View Full Version : Fuel, Oil, Cleaners & Other Maintenance
Pages : 1 2 3 4 [5]
  1. Redline or Genuine Honda ATF
  2. 89 octane = reduced mpg
  3. Clutch Fluid Flush
  4. anybody use antiseize ??
  5. Still at a loss on this sparkplug thing
  6. Octane Question
  7. too much oil
  8. Gas stations cheat you?
  9. 1.7 liter 04 em2
  10. oil drain bolt washer ?
  11. Gas Line Antifreeze?
  12. What Antifreeze
  13. i need a new power steering reservoir and..
  14. royal purple adds hp !!!
  15. Is Time For My Tune-up
  16. Front rim's really greasy
  17. honda dealer and maintenance
  18. new oil pan
  19. LubeControl LC20 and FP60
  20. 13.2 sux I want more
  21. 30-50 mph- Acceleration problem
  22. B&M trick shift ATF
  23. Any recommended maitenance at 80,000 miles that I may of forgot about?
  24. More than you need to know about engine oil.
  25. Here is Excel MPG Template
  26. Amsoil XL5w-20
  27. Castrol Oil
  28. Door weather strip lubercant
  29. 60,000 Tranny Fluid Change?
  30. Fuel Mileage for 2002-05 Civic Si/SiR
  31. Cleaning KnN Filter on Intake
  32. Engine Coolant
  33. changing tranny filter
  34. 30k mile maintanence?
  35. 41 mpg~!!!!!!!!!!!!!!!!!!!!!!
  36. fuel injector cleaner / techron
  37. oil change problem
  38. Tranny fluid..
  39. Did mobil get bought by lukoil?
  40. WD-40 on wheel studs and lug nuts?
  41. maint. req'd.
  42. Prestone Brake Fluid
  43. Do you bring your own oil and filter?
  44. Would these SparkPLugs Work. "Hurry"
  45. Seafoam
  46. Are all synthetic oils the same?
  47. AEM's New DryFlow Air filter
  48. Is anyone running the DSM "Blue tops" 450cc?
  49. my experience with changing tranny/motor oil
  50. Changinh plugs
  51. EGR valve, where is it, and how can I block it off.
  52. Radiator flush vs. cleaner
  53. lc20 oil treatment review
  54. what would you do to improve gas mileage and power?
  55. ok so has anyone ever...
  56. Timing belt and fliuds change???
  57. Stupid Brother, NEED HELP !
  58. Gas mileage.
  59. Why do I have blue coolant?
  60. Mechanics and techs alike....
  61. o2 sensor replacement interval
  62. Best oil to use for 02' Honda Civic
  63. Fp60 ??????
  64. Jack Stand or Ramps?
  65. motor sitting for months?
  66. vtec-e
  67. Urban myth?
  68. Synthetic Oil Question.
  69. Wed August 31st last day for Lubecontrol.com Group Buy
  70. gas quality
  71. 20k Maintenance
  72. Free Garmin eTrex or Magellan GPS!
  73. the marketing of synoils (synthetic oil)
  74. need a straight answer
  75. oil filter
  76. Cabin Filters
  77. Lubecontrol.com Group buy expiring soon!
  78. Fuel consumption.
  79. Just received my LubeControl products!
  80. Approaching 70k Miles: What Maintenance to Be Done?
  81. K&N filter cleaner on OEM airbox filter
  82. removing bolt-ons = better mpg?
  83. Honda Type 2 50/50 Coolant - where to get?
  84. first time synthetic ?
  85. fuel tank max fill
  86. 89 Gasoline
  87. Aftermath of additives with oil change...
  88. oil question???
  89. What kind of Oil to use
  90. Independent Motor Oil Testing??
  91. Oil leak
  92. Time for a tune up need some info...
  93. coolant change
  94. redline used with normal oil filter?
  95. Best Tranny fluid (automatic)?
  96. engine oil question
  97. (Newbie) Hanging Exhaust?
  98. car fluids?
  99. OIL: from an engineer's view
  100. FP60 Discount
  101. post your mileage
  102. Stock Air Filter Box ??
  103. Best Place to Jack up front of car...
  104. K&N oil fliter OR Moblie 1 oil fliter
  105. seamfoam brake booster hose where ???
  106. What new sparkplugs to get?
  107. K&N filter for AEM V2 intake?
  108. right spark plugs?
  109. I Need All The Power I Can Get
  110. Amsoil syncromesh
  111. torco sr1 oil
  112. how often to change the injen cold air filter
  113. how to change spark plug
  114. fuel 98 civic?
  115. ok to go thinner weight?
  116. 10,000 miles W\O oil change
  117. Wheres The Oil Filter?
  118. 21 points inspection
  119. When is it time to change Radiator?
  120. where to get the honda stuff
  121. B16A swap, fuel filter leaking???
  122. fp60 is amazing
  123. Fuel Pressure Regulator Installation
  124. Doing my own oil change for the first time~~
  125. Anybody ever use the Honda Performance Tranny Fluid?
  126. Starter
  127. First Oil Change for Me and the Car, Require Assistance
  128. Cleaning particular parts of the engine?
  129. Is adding additives to your Eng. good?
  130. Mobil 1 extended performance
  131. fumoto oil drain valve review
  132. just got 440cc injectors where do I get clips?
  133. Castrol GTX or Exxon Superflow
  134. Whats stock injector size? also would 440cc injector be good for turbo?
  135. remove bumper to change oil.
  136. AC Help
  137. is there a clean way to change an oil filter
  138. Real Racing Oil: Motul
  139. Power Steering Flush Procedure?
  140. wat type of coolant do i use?
  141. Group Buy is up
  142. Redline Vs Royal Purple
  143. Amount of oil
  144. Free Garmin eTrex or Magellan GPS!
  145. Oil Recommendations
  146. Link to dino UOA with LC20
  147. lube control's fp60
  148. Wheres The Diy For Mt Fluid Change
  149. BG Fuel Products?
  150. Are they the same?
  151. Going from 10W-30 back to 5W-20?
  152. will it hurt?
  153. 5w-30 vs 5w-20 vs 0w-20 vs 0w-30
  154. Oil Changes... First and Thereafter
  155. How to siphon gas out of our cars?
  156. Gas Mileage
  157. 60k questions, save me from honda dealers
  158. Walbro fuel pump
  159. Acetone test
  160. need some advice
  161. great engine oil, and great for your wallet!
  162. What kind of aftermarket fluid for A/T ?
  163. Maintenance light for oil change?
  164. coolant change instructions and reminder
  165. taking a 3000+ mile trip, what to do?...
  166. Question about octane booster
  167. very low mileage in city AND highway...why?
  168. Nasty Odor From A/C?
  169. Anyone using an S2000 oil filter?
  170. type of oil
  171. "Pour in the performance?"
  172. exxon/mobil vs chevron
  173. Air Filter
  174. Anyone with SLPs Return Fuel Kit, I need pics
  175. K&N Air Filter
  176. Oil pan gasket, 95
  177. Engine Shampoo Question
  178. "Higher Milage" 5w30 or 5w20?
  179. atf
  180. A/C fuel DIY?
  181. hamp filter
  182. Detergents and Magnesium?
  183. Maintenance required light
  184. 60k - what should be done?
  185. 40,000 MI service?
  186. injector cleaning service??
  187. lubecontrol gets the thumbs up. :)
  188. 5k,10k,15k oils
  189. Oil Changes & 10,000 mile maintenance
  190. Sounds when starting car
  191. New Car Oil Change
  192. oil leak?
  193. seafoam
  194. Fuel Sending Unit/sender...
  195. didn't change the oil filter
  196. help with timing belt
  197. Molybdenum helps with the break-in process, but when you change your oil...
  198. Automatic Transmission oil cooler ?
  199. NGK Spark Plugs
  200. hi flow cat + gasoline
  201. Adding oil before 1st oil change
  202. road trip
  203. antifreeze?
  204. how often to change fuel filters???
  205. scheduled service maitenence
  206. Fuel Power and Lube Control group purchase interest?
  207. Fuel Gauge problems
  208. Maintenance light
  209. fluids in our cars.....
  210. loud pop from my car
  211. Super gas mileage!
  212. tranny
  213. Car makes sounds .. any help
  214. Fuel Rail, 99-01 the same? HELP!!!
  215. coil-over plugs
  216. Automatic Transmission Fluid. What kind?
  217. Oil Change Question
  218. How Do You Change Manual Transmission Fluid
  219. water in gasoline?
  220. Do you use Fuel / Oil additives ?
  221. 5000k for oil changes?
  222. Can't find mobil1 5w-20 anywhere!!
  223. FP effectiveness at 5k intervals?
  224. FAQ about oil, fuel addatives, filters, and more
  225. Gas prices around the world
  226. Highly recommed Used Oil Analysis
  227. Oil add FAQ's
  228. Fuel additive FAQ's
  229. Is gas any different?
  230. Fuel quality declining
  231. Good to be here!
  232. New top tier gas
  233. don't use premium gas
  234. Fuel System Cleaners and Additives?
  235. Which fuel additive to use at 30k?
  236. oil/fuel Additives
  237. 10,000 mile oil change
  238. 5w 20w Motor Oil
  239. Fuel Economy
