B&M trick shift ATF - Honda Civic Forum
B&M trick shift ATF
Old 11-08-2005
goodtimes's Avatar
B&M trick shift ATF
has anyone ever hurd of it... i wanted to know if its good or bad for auto's
Thanks
Matt C.
goodtimes is offline
Old 11-08-2005
7thgen Power Maker
dezod's Avatar
I used it. Cold transmission shifts with a tranny cooler were a little hard, but once it warmed up.....No probs!
dezod is offline
Old 11-08-2005
goodtimes's Avatar
so did it help you out with the faster shifts between gears???
Old 11-09-2005
7thgen Power Maker
dezod's Avatar
No. That is not the purpose of a transmission fluid.
dezod is offline
Old 11-09-2005
goodtimes's Avatar
then why pick this one over any other
Old 11-11-2005
the honda fluid has smaller molecules made specifically for the tranny. i would only use honda atf.
gearbox is offline
Old 11-16-2005
7thgen Power Maker
dezod's Avatar
It held up better on a boosted auto. Higher break down temps vs stock oil.
dezod is offline
Old 11-20-2005
konrad is an unknown quantity at this point
just use honda atf.
konrad is offline
Old 11-20-2005
taehoshi's Avatar
taehoshi is an unknown quantity at this point
is it just me, or is the transmission drain plug impossible to open by a hand wrench?
taehoshi is offline
Old 11-20-2005
7thgen Terminator Ninja
booba5185's Avatar
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
quite possibly
booba5185 is offline
bolt-on-bandito
30
08-08-2018 06:45 AM
ricer_em2
05-11-2016 09:09 PM
sesi
10-01-2015 03:03 PM
ThatGuy913
09-28-2015 06:35 PM
Quick Reply: B&M trick shift ATF
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
