Super gas mileage!
Old Mar 31, 2005
mdb_foxmx's Avatar
mdb_foxmx is an unknown quantity at this point
Super gas mileage!
Hey guys...I took my civic (04 ex coupe) to JIffy Lube a while back, and the salesman tried to sell me mobil 1 synthetic 5w-20. I said ok, but on the invoice, M1 10w-30 was listed. I didn't really believe him when he said that that was a "typo." But, I didn't really care either. I just drove my car for a while thinking "if something screws up with the oil, it's on them." Well, I got a little worried, so I decided to change the oil myself. I bought some castrol syntec 5w-20 and changed the oil. My gas mileage before the change was around 33-35 mpg. What is it now, you ask?... Try 40mpg!! And this wasn't all highway driving! MOST of the time on the last tank was spent in traffic, WITH the ac on (low). I figured maybe it was a fluke, but I just refueled again today, and it was right at 39.4mpg! Amazing, yes? Anyone else getting that?
Old Mar 31, 2005
Vantage's Avatar
Vantage should not be trusted
ive never heard of oil maknig better gas milage... only extra HP, but thats cool, i might have to try that.
Old Mar 31, 2005
i8dabomb's Avatar
I love to suck t3h c0ck & am supr ghey
i8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nice
lol maybe time for the castrol?
Old Mar 31, 2005
Chris3k2's Avatar
Chris3k2 is an unknown quantity at this point
sounds interesting... I've never heard of it either though and I didn't know oil can give u extra HP?? that's coo
Old Mar 31, 2005
doubledeuce2k2's Avatar
5w20 is a lighter weight. they recommend that oil for your engine. so why shouldn't it perform the best?
most places don't have bulk 5w-20 "on tap". meaning they have to crack open bottles off the shelf. bulk oil for them is under a buck a quart, off the shelf a couple bucks. so what are they gonna do? give you bulk oil everytime you can.
i bet you anything it was not a typo... don't go back, i might even call to complain.
thats good milage but not uncommon. i got 38 in an auto w/ a/c running. it's not super oil, just the reccommended
Old Apr 1, 2005
Vantage's Avatar
oil can free up HP, not make HP. The free it up because they cause less friction. And less friction = less heat, and less heat = more power.
Old Apr 1, 2005
exactly. it's like running with pants and running with shorts. you aren't physically any faster in shorts, but you will have less slowing you down. and you'll stay cooler
Old Apr 4, 2005
2K1Civic17"Gabe's Avatar
I get about 30, and 35 was probably the best I ever got.
Old Apr 4, 2005
S2000man01's Avatar
O RLY
castrol syntec is crap. in fact, it's hardly any better than valvoline regular minoil. don't use castrol syntec.
oil will do neither better gas mileage OR more hp.
you're talking maybe 1hp at most. if that. and that's only if you wait a long *** time before changing your oil, so it's overly cruddy and dirty and thick. if you change your oil at normal 5k intervals, for example, you're not going to free up any horsepower when you change your oil.
Old Apr 8, 2005
mdb_foxmx's Avatar
why do you say castrol is crap? I haven't read much about the different oils... Just want to know what your basis is for that.
Old Apr 8, 2005
i8dabomb's Avatar
hmm i suppose i wont use castrol cuz s2000man01 knows EVERYTHING!
Old Apr 8, 2005
S2000man01's Avatar
O RLY
haha loser.
castrol is not as good compared to other synthetics. in one test, castrol syntec actually does WORSE than it's regular old oil does! and it's in one of the more important tests!!
1. All the oils were 10w30 viscosity
2. The oils tested were:
Amsoil (syn)
Castrol GTX Drive Hard (mineral)
Valvoline Synpower (syn)
Mobil Drive Clean (min) - isn't this the rebadged Honda oil?
Pennzoil Purebase (min)
Quaker State (Syn)
Quaker State Peak Perf (min)
Castrol Syntec (syn)
Valvoline (min)
Pennzoil Synthetic (syn)
Mobil1 SuperSyn (syn)
The following ASTM tests were run:
Thin-film Oxygen Uptake ( D-4742)
High Temp/High Shear ( D-4683)
NOACK Volatility ( D-5900)
Pout Point (D-97)
Total Base Number (D-2896)
Cold Cranking Simulator D-5293)
4-Ball Wear (D-4172)
Test 1: Thin Film Oxygen Uptake:
Measures the oxidation stability of an oil.
The induction time (break point) in minutes is measured. The test uses standard amounts of fuel dilution, soluble metals, and water to offer a real-world applicability.
Results for this test(all units in minutes):
Amsoil: >500 (no break)
Mobil1: 397
Pennzoil Purebase: 242
Castrol Syntec: 221
Valvoline: 219
Vavoline SynPower: 211
Mobil Drive Clean: 209
Quaker State Peak Performance: 192
Pennzoil Synthetic: 159
Quaker State Synthetic: 159
Castrol GTX Drive Hard: 132
castrol syntec did ok here
Test 2: High Temperature/High Shear (HT/HS)
Measures a lube's performance under severe heat and shear (mechanical stress) as would be found in the journal bearings under heavy load. The units displayed are viscosity based, using the centipose unit (cP). The minimum spec for a 30w is 2.9 cP.
Results for this test (all units in cP):
Amsoil: 3.51
Quaker State Peak Performance: 3.37
Castrol GTX Drive Hard: 3.35
Vavoline SynPower: 3.30
Mobil1: 3.30
Valvoline: 3.30
Mobil Drive Clean: 3.28
Pennzoil Purebase: 3.16
Quaker State Synthetic: 3.15
Pennzoil Synthetic: 3.14
Castrol Syntec: 3.13
note castrol syntec was the WORST here. and high temp/shear is not something I would want an oil to be WORST at in my car!
Test 3: NOACK Volatility.
Measures the evaporative loss of lubricants in high temperature conditions. The higher the number, the thicker the lubricant will become. API SL and GF-3 specs allow for a 15% evaporation limit. In this test, obviously, lower is better. Syns almost always have an advantage due to their monomolecularity.
Results for this test (% weight loss):
Amsoil: 4.86
Vavoline SynPower: 7.03
Castrol Syntec: 7.77
Quaker State Synthetic: 7.80
Pennzoil Synthetic: 8.15
Mobil1: 8.92
Castrol GTX Drive Hard: 8.93
Quaker State Peak Performance: 10.63
Mobil Drive Clean: 10.83
Pennzoil Purebase: 10.93
Valvoline: 12.18
Test 4: Pour Point
This test reveals the lowest temperature at which a lubricant will flow when cooled under test conditions. The lower, the better the product will perform in getting from the oil pan to the upper oil galleys, and in providing oil pressure quickly. Synoils generally are the best, because they are free of wax crystals, but today's mineral oils are better refined to remove wax impurities, and use advanced pour point depressant additives to help offset the synoils' intrinsically better properties.
Results for this test (all units in degrees Centigrade):
Amsoil: -48
Mobil1: -46
Vavoline SynPower: -46
Castrol Syntec: -43
Pennzoil Synthetic: -40
Quaker State Synthetic: -40
Pennzoil Purebase: -37
Valvoline: -37
Mobil Drive Clean: -37
Castrol GTX Drive Hard: -37
Quaker State Peak Performance: -34
Castrol Syntec did ok here, but this test only affects those who drive in very cold temps
Test 5: Total Base Number (TBN)
TBN displays the lubricant's reserve alkalinity, and is, of course, the opposite of TAN (total acid number). A high TBN will help resist the formation of acids from sulfur and other sources. It is also a good indicator of reserve resistance to oxidation. The higher the number, the superior ability to suspend contaminants and the greater the ability to provide long-drain intervals
Results for this test (all units in mg KOH/g):
Amsoil: 12.34
Vavoline SynPower: 11.38
Castrol Syntec: 10.39
Pennzoil Synthetic: 9.73
Mobil1: 8.57
Valvoline: 7.88
Quaker State Synthetic: 7.82
Castrol GTX Drive Hard: 7.74
Mobil Drive Clean: 7.71
Quaker State Peak Performance: 7.55
Pennzoil Purebase: 7.40
Castrol did ok here
RR's comments: I was very impressed with all the oils, as the mineral oils have significantly improved, consistent with previous comments about how mineral oils are closing in, and that the GF-3 spec has resulted in very good performing products. Mobil1's showing is the best i have seen for that product, which usually was in the 5-6 range previously. It certainly also supports my previous comments that the 3K oil change "necessity" is out of place with current technology. Like an enema for a dead man, while it may not help to do a 3K change, it wouldn't hurt I guess.
Test 6: Cold Crank Sumulator
This one determines the apparent viscosity of the oils at low temperatures and high shear rates, simulating the dreaded cold start. It has direct applicability to engine cranking, the lower the number the better in terms of stress on the battery, starter, etc. A 10w is tested at -25degF and must show a vis <7000 cP to pass.
Results for this test (all units cP at -25degC):
Pennzoil Synthetic: 3538
Amsoil: 3590
Mobil1: 3967
Quaker State Synthetic: 4142
Vavoline SynPower: 4541
Quaker State Peak Performance: 4620
Castrol Syntec: 4783
Castrol GTX Drive Hard: 5804
Pennzoil Purebase: 5936
Mobil Drive Clean: 6448
Valvoline: 6458
castrol did ok, but worse than the other synoils.
RR Comments: If you live and drive your car in very cold climates, the advantage of the synoils is obvious. Keep in mind that the NOACK performance figures here as well, as this tests hows the performance of fresh oil - after a few thousand miles, the oils with higher volatility will likely have thickened, unless there has been high dilution from fuel, such as can occur if excessive startup idling warmups are employed.
So it's not "crap". And I was a bit harsh in my first post. However, for the money, there are better performing synthetics out there.
Old Apr 18, 2005
S2KREY's Avatar
formerly 2k1CivicRacer
S2KREY is on a distinguished road
there was a article in import tuner about the diff type of oil. read it but eh... oil is oil but that just my 2 cents
Old Apr 18, 2005
S2000man01's Avatar
O RLY
for those who look no further, oil is oil. but for those that read about it, do the tests, and find the research done, every oil is different and some are far better than others.
Old Apr 18, 2005
mdb_foxmx's Avatar
so...where can I buy amsoil 5w-20? That seems to have done the best overall in that particular test, usually by a good margin. Should I ask an autozone rep to order it?
Old Apr 18, 2005
zen_master's Avatar
do you guys realize that MOBIL 1 now makes 5W20 instead of 0W20???
0W20 will be dropped from their product line! i just realized about this in my local wal-mart!!
guess i'll switch to 5W20 =)
Old Apr 19, 2005
VP Stylee's Avatar
VP Stylee is an unknown quantity at this point
i always use 5w20 for my car but ive been using the castrol syntec blend instead of full synthetic. im oging to try valvoline synpower full synthetic next time i change since i got some coupons at the last car show i went to
Old Apr 19, 2005
S2000man01's Avatar
O RLY
valvoline synpower has a very good base TBN number. you can go probably 10,000 miles or more between oil changes.
Old Apr 19, 2005
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i got 39mph when i drove to sanfranz...all free way
Old Apr 19, 2005
UTICivic's Avatar
UTICivic will become famous soon enoughUTICivic will become famous soon enough
I use whatevers on sale or have a coupon for. Oil is oil. Car still turns on and drives like it supposed to. Still get the SAME gas milage(35-40mpg). All that name brand stuff, PFFT! I say..its like Louis Vuitton and Anchor Blue, both put clothes on your back. Just one costs more than the other.
Old Apr 20, 2005
S2000man01's Avatar
O RLY
again. couldn't be FARTHER from the truth. sure they're all the same....
Amsoil (syn)
Quaker State (Syn)
Valvoline (min)
Pout Point (D-97)
Mobil1: 397
Castrol Syntec: 221
Valvoline: 219
Amsoil: 3.51
Mobil1: 3.30
Valvoline: 3.30
Amsoil: 4.86
Mobil1: 8.92
Valvoline: 12.18
Test 4: Pour Point
Amsoil: -48
Mobil1: -46
Castrol Syntec: -43
Valvoline: -37
Amsoil: 12.34
Mobil1: 8.57
Valvoline: 7.88
Amsoil: 3590
Mobil1: 3967
Valvoline: 6458
Test 7: Four Ball Wear
This one is a good indicator of the wear protection of a lubricant, although in the real-world it is should be factored in with the TBN of the oil. Three metal ***** are clamped together, and a rotating 4th one is pressed against them in sliding contact. A scar is produced, since at some point the film strength (resistance to being squeezed out) of the oil will be exceeded. The scar is then measured, and the smaller the average wear scar, the better. This test is affected by both the base stock of the oil, and its additive package.
Results for this test (all units in inches):
Amsoil: 0.40
Castrol Syntec: 0.45
Vavoline SynPower: 0.55
Quaker State Synthetic: 0.55
Mobil Drive Clean: 0.55
Pennzoil Synthetic: 0.60
Mobil1: 0.60
Valvoline: 0.60
Castrol GTX Drive Hard: 0.60
Quaker State Peak Performance: 0.60
Pennzoil Purebase: 0.65
Old Apr 22, 2005
honda860's Avatar
honda860 has a little shameless behaviour in the past
thats cool man when i bought my car i but a full tank of gas in at 13 miles when i bought the car the first tank of gas i put in it was at 580 miles. SO i guess thats pretty good too. I havent got my first oil change yet but ithink im gonna go synethetic also. Honda gives me 6 free oil changes so i wanna use those first but i dont knowif they will give me synthetic but anywayz nice mpg's man
Old May 4, 2005
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
it is very noticable when i use synthetic mobil 1 or just plain oil from honda. the engine just feels smoother on the mobil 1. i noticed it right away. i had mobil 1, then i took it to honda for a cheap price oil change. when i drove it again, it felt sluggish. then i switched back to mobil 1 and it felt better again. then i repeated the same cycle. i will only used full synthetics from now on. i might even consider redline oil ($8+ a quart!!! dang).
Old May 4, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
huh. according to those tests, amsoil is one of the best oils? ... how does it compare to royal purple or redline?
Old May 4, 2005
Jrfish007's Avatar
Royal Purple and red line are great. Far better IMO, and I do my own testing , although I've only used Royal Purple and tested of those two. Now days I just use what ever is on sale, not becaseu I think oil is oil, becasue the car leased. You never want a car that came off my lease
Edit: The cars I mod and intend on keeping use Royal Purple, but they may get 2,000 miles a year.
Old May 4, 2005
Jrfish007's Avatar
About time, why did theye ver make 0w20 anyway? I know very few cars that use that.
Old May 4, 2005
goodtimes's Avatar
i like redline thats the only oil i put in.....
Old May 4, 2005
zen_master's Avatar
i wonder about that too..................
however, since they put a note on the bottle...saying that "it's alo for the application of 5W20 such as Ford and Honda"
i guess then people start to use them...for their ford focus or something..
anyway....now they threw that one out.....and they start making the 5W20...
which is cool.
Old May 4, 2005
Jrfish007's Avatar
Easy, lol, I have a Ford too
Old May 4, 2005
zen_master's Avatar
LOL..
that's actually when i realize.....that they're always ran out of that product.......maybe because a lot of domestic start using them?
