help with timing belt
Old Apr 19, 2005
cmeias's Avatar
cmeias is an unknown quantity at this point
I am changing my timing belt this weekend and am not sure where the pullies line up for tdc.
does anybody have any information on this. I cant afford a helms book just yet but its time to change the belt and need to know.
Thanks
Old Apr 20, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
how often do you do this? miles
Old Apr 20, 2005
2K1Civic17"Gabe's Avatar
honda says 110,000. I am approaching 100,000 and am boosted, so Ill be changing mine before 100.
Old Apr 21, 2005
Blk2k2civy's Avatar
Blk2k2civy is an unknown quantity at this point
what if you over reved and bent some valves could it of possibly stretched the timeing belt
Old Apr 21, 2005
S2000man01's Avatar
O RLY
I never have to change my timing belt. lol
over rev probably won't damage the timing belt, but IMO, since you're replacing valves and the like, you might as well change the belt too right away.
Old Apr 23, 2005
streetglower's Avatar
Thanks
on the camshaft pulley, crank pulley, and another pulley, there are marks that line up with marks on the block. When you get the new belt on, all the marks should line up with the marks on the block. if they dont, you have to redo it untill they do.
Old Apr 23, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
the cam gear has marks that line up with the top edge of the head and on one of the spokes it says "UP" that faces..... you guessed it, up hehe Now on the crankshaft there is a timing belt drive pulley. There should be a notch in the face of it that is supposed to line up with the little arrow that sticks out of the oil pump face. The keyway in the crank should face straight if I remember correctly. Make sure everything lines up exact. If you arent sure either stop and ask someone or turn the motor over very gently clockwise with the plugs out with a ratchet to make sure there is no contact with the valves. That way at least if its wrong it wont ruin your motor on start up. If its wrong you will know, and then have to start all over again. Bottom line is it really should be done right the first time though.
Old Apr 25, 2005
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
^What he said. ALSO! Be really carful tightening the belt as well. When I did my 95 DX I drove around with this whirring sound coming from my hood. I asked Honda and they said it was my tensioner making the noise. Basically takes the longevity down to about 50k as opposed to 100k. I had to break it all down again and loosen it. After you finish, make sure you listen for that on the test drive... I actually don't know how the set-up is on the 7th gen, but I'm sure it's generally the same layout.
Also, I see alot of people using AEM cam gears, would that do anything for my car or is it only ideal for highly tuned Vics?
Old Apr 25, 2005
if your belt starts making noise or is loose, you have a bad tensioner. If the tensioner makes noise, it needs replacing. The timing belt doesnt need to be adjusted, the tensioner keeps the tension at the proper amount, unless its bad.
Old Apr 25, 2005
...ever grinning...
Sorry
I meant after I did the job it was making noise. And it was a brand new tensioner; I don't know about the 7th gen's, but on the b15 I had the timing belt tension was adjustable by a small bolt that went through the center of the tensioner pulley. I made mine too tight first time around and it was making the noise. After I loosened it a bit the noise went away.
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
