5k,10k,15k oils
SICCMADE
Rep Power: 0 5k,10k,15k oils
ok so now (i cant remember who) makes oil for 5k, 10k, and 15k before you change it. Anyway even if they state it can go up to so and so miles would it be smart to run oil for that long, 15k is lot of driving i would get nervous leaving my oil unchanged for that long?
Retired suspension supermod.
Rep Power: 387 If it synthetic, and you don't beat the crap out of your engine, then you can get at least 10k. I usually do it every 7500 but I do autox. My wife's sentra gets an oil change every 10k.
Jap-Euro Fusion
Rep Power: 399 those new mobil oils are not synthetic. they're dinopiss with additives. The oil may last, but you should change the filter more often than 15000 miles.
O RLY
Rep Power: 375 yeah, for oils that last 15,000 miles (i'd think synthetic will be better, as their TBN number is always higher than dino oils), you should still change the filter at every 7500 or so.
Jap-Euro Fusion
Rep Power: 399 Well then why bother with the 15000 oil? They've been advertising Mobil 1 to go that long forever. Delvac 1, the fleet vehicle/heavy truck stuff... will go for 20000 or more.
1 Post
Rep Power: 0 Marketing, that's why. The public at large had shied away from synthetic oils because they aren't aware of the extended drain benefits. Now by calling oils "Super Clean 5000" or "Super Duper Protect 10,000", Joe Schmo becomes instantly aware of how far the oils can go.
Doesn't Honda recommend oil filter changes every other oil change? I don't exactly believe that, I mean if I'm going to take the time I might as well change everything, but if that's the case I doubt anyone would see a problem getting 10K+ out of a filter.
SidCivic
17
08-23-2015 03:14 AM
loosescrew84
16
08-11-2015 07:08 PM
fafa1234
08-08-2015 06:42 PM
fecrni
08-08-2015 06:15 PM
Green02civic
07-27-2015 10:48 PM
