"Pour in the performance?"
Old May 17, 2005
NiceRide's Avatar
NiceRide is an unknown quantity at this point
Just saw a commercial for Mobil 1's supersyn synthetic oil. It shows a car speeding around a race track. They repeated a couple times to choose Mobil 1 and "pour in the performance". But what performance are they talking about exactly? Last I heard, putting in a synthetic oil will do practically nothing in terms of HP gains and the car drives pretty much the same. Is this just BS marketing?
Old May 17, 2005
ajhdragon's Avatar
7thgens official a$$hole
mobil 1 just makes really good oil and synthetic will let the car run better longer.
Old May 17, 2005
S2000man01's Avatar
O RLY
There are a few advantages to using synthetic. Longer oil change intervals, and in general, they are better at high temp/high shear properties, etc. In your civic, if you're not racing it, then the only reason to really use synthetic is simply for the extra protection if you live where temps get really high or really low, and for longer oil change intervals. (you can easily go 10k before changing your oil)
Old May 17, 2005
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
"Performance" can mean many things.
Old May 18, 2005
2K1Civic17"Gabe's Avatar
Post
would 4000 be ok for a turbo civic. I have always changed it at 3000 even stock (with synthetic-mobil1), but there are times I dont have time to change it or get to a shop. WOuld this be ok, not all the time definately, Id rather change it at 2500.
Old May 18, 2005
reefer_bob's Avatar
reefer_bob is an unknown quantity at this point
Only way to REALLY tell, is to get the oil analized by a lab (Blackstone and others).
Do you have a stock pan? Any oil coolers? Do you know how hot your oil gets?
I run 5k on my oil in my twin turbo Audi. But, my car has 7qts of oil capacity. With a stock oil pan of 3.75 quarts, 5k miles may be too much. Heck, 3k may be too much if you really abuse it.
Check out oil labratories online.
Old May 18, 2005
haha, reefer^^. cool name.
I dont know how hot it gets, I need to invest in a few more things for my car. But right now Im too busy getting a clutch, clutch master/slave cylinder, and tranny mount. My car got pretty busted the other day.
I use 4.5 qts of oil, btw. stock pan (modified), and no coolers (yet)
Old May 18, 2005
reefer_bob's Avatar
Thanks on the name...
Good deal on having more oil... I'm always leary of running a turbo on an engine that was not originally designed for a turbo. Cooling is always such a big issue. Keeping that oil at a reasonable temp (especially in AZ) I would think would be an issue as well. I would reccomend an oil temp gauge. That and buying a kit from Blackstone to get the oil tested if you're that concerned about it.
Old May 19, 2005
At least I dont have to drive my car in the heat for a couple weeks. It gets soooo damn hot here, its gonna be 100 degrees tomorrow and 110 within a few days. Time for some new record temps, damnit.
Ill check into an oil temp gauge in the next couple weeks. thanks
Old May 19, 2005
JxL_o2Lx's Avatar
JxL_o2Lx is an unknown quantity at this point
I use synthetic oil ever since i got nitrous. Haven't really noticed a difference although from friends suggestions it's recommended.
Old May 19, 2005
masarak's Avatar
What will synthetic oil do for me?
styles234
21
Nov 19, 2019 07:23 AM
MamaBear2015
Sep 27, 2015 06:31 PM
Jrosa
Sep 14, 2015 08:24 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
