60,000 Tranny Fluid Change?
Old Oct 30, 2005
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, in my manual it says that it is recommended that I change the transmission fluid at 60,000 miles in my 01' civic and i'm about to that time. Is this supposed to be a partial drain or complete fluid change?
Old Oct 30, 2005
eye_see_you's Avatar
let the devil out
I had to change mine out earlier than that but when I rebuilt my tranny I decided to use REDLINE tranny fluid . If you switch it will be a noticeable difference.
Old Oct 30, 2005
sodaks2k's Avatar
sodaks2k is an unknown quantity at this point
Do you have a manual or an auto? If it still feels smooth, you could just use Honda MTF if you have a manual. If it is a manual, it's very simple to do.
Loosen the fill plug and remove it.
Loosen the drain plug and remove it.
Let the fluids drain for a good half hour, or longer if you have time.
Replace the drain plug (with new crush washer) and torque to specs.
Replace the tranny fluid. When the tranny fluid starts to come out of the fill plug, insert fill plug (with new crush washer) and torque to specs.
That's it!
Old Oct 30, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
eh ... I would change mine long before 60k miles ... maybe every 20-25k miles ...
the manual also states that you should go with 5000 mile oil change intervals -__-;;
Old Oct 30, 2005
sodaks2k's Avatar
I usually go every other oil change.
Oil is, and has been, a much better product than when first released. 5000 miles is no problem for todays oil. The 3000 mile oil change interval was started buy oil companies and oil changing places like jiffy lube to get you (the consumer) to buy their product more often. A lot of manuals state than you can go 7500 miles on an oil change, if you drive mostly highway miles.
Old Oct 30, 2005
MIVtec's Avatar
MIVtec is an unknown quantity at this point
I did my 5spd 01 ex @ 50,000 with REDLINE MTL, and it made the tranny feel new again.
Old Nov 3, 2005
ZSKCivic01's Avatar
Extreme Member
I have an automatic and my civic is an 01', I have had it changed one other time around 30k I believe. I am pretty sure I can do a partial change if I have the DIY but for a full I would have to take my car in. So partial fluid change or the entire tranny?
Old Nov 3, 2005
fullgrown's Avatar
<---- I am really this short in person!
fullgrown is an unknown quantity at this point
is it totally different to change transmission oil for auto and manual? from what i got from reading this, it sounds like auto is a beatch to do.
Old Nov 4, 2005
ZSKCivic01's Avatar
Extreme Member
No one is answering my question, I don't mind getting it done professionally, but do I need a full transmission flush or a partial? I'll also try that Redline ATF if I can find it! Thanks.
Old Nov 4, 2005
J_UNIT's Avatar
Like my dad used to say, Just bend over and take it like a man, son
J_UNIT should not be trustedJ_UNIT should not be trustedJ_UNIT should not be trustedJ_UNIT should not be trustedJ_UNIT should not be trustedJ_UNIT should not be trustedJ_UNIT should not be trustedJ_UNIT should not be trustedJ_UNIT should not be trustedJ_UNIT should not be trusted
full tranny flush. if it's an manual, u can do it urself, but if it's an auto, you have to get it completly flushed by a machine. I have an auto and took my car into the shop where my friend's dad works and got it done. and yes, I did mine at 60k miles.
Old Nov 4, 2005
J_UNIT's Avatar
def. do the full tranny flush. think of it this way, would you partiallay change the oil after 1000 miles, if you were to change it at 1000 miles?
Old Nov 4, 2005
Huney's Avatar
Huney is an unknown quantity at this point
"Is it totally different to change transmission oil for auto and manual? from what i got from reading this, it sounds like auto is a beatch to do."
Manual doesn't have a filter so all you do is remove the drain plug and drain then replace the oil. Automatic must have a filter and if the filter has contaninants on it you need a flush, if not don't pay for something you don't need. Our Ford says change auto tranny oil every 50K miles but I know guys who went 100K miles with no problems, and they drive hard. Thing is, trans oil has no opening to the outside so no way for dirt to get in but gets very hot so in time probably loses some of it's characteristics.
A word of caution: Read the manual and be sure to use whatever tranny oil they specify. I had an older Mustang with stick shift and manual said use Mercon auto tranny oil. HUH? Undoubtedly a misprint so I went by a automatic transmission shop and the mech said the manual is right. Seems the synchronizer rings are made out of some fibrous material and if you use regular SAE 80-90W gear oil or anything but Mercon fluid it will cause the synchronizer rings to deteriorate. Learn something every day.
Red Line tranny oil: Never heard of it and I have a long way to go to 50K mi but I found this interesting. "Redline D4 ATF: A fully synthetic ATF designed to satify the requirements of Dexron III, Mercon and Mercon V, while satisfying GL-4 oil requirements. Superior stability allows high temp operation without varnishing valves and clutches."
Hmmm . . Veddy interest-ink. Local Honda shop foreman very knowledgable so will have a Pow Wow with him. Ya'll have a nice day. Huney.
Old Nov 5, 2005
army005's Avatar
army005 is an unknown quantity at this point
That's it!
Unfortunately, didn't get a manual with my used 02 civic si, so anyone tell me what the torque specs are for the transmission plugs?? Also, is Red Line synthetic the best brand for transmission oil for this model?? See a lot of folks using it.
Old Nov 5, 2005
wow that is way overdue. auto tranny likes new fluid every 10k at least. the effects wear off after 5k tho. the tranny is junk. and for auto, I would only use honda atf.
Old Nov 5, 2005
sodaks2k's Avatar
The torque specs for the RSX tranny are 33 ft/lbs for the fill plug and 29 for the drain plug, theres a good chance yours are the same. It seems a lot of people are happy with the Redline. I used a bottle of this
http://www.hardtopguy.com/store/cust...uctid=254&cat=
and a bottle of this
http://www.pennzoil.com/products/gea...cro_fluid.html
The Friction Modified gives more solid shift engagement (increases friction of syncros) while the regular syncromesh increases lubricity. My wife noticed a differnce right away, as did another local member who used the same fluids.
Old Nov 11, 2005
scrimp's Avatar
scrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of light
Does anyone know have an estimate of how much it is to have it done at a honda dealership?
Old Nov 11, 2005
JP375's Avatar
JP375 is an unknown quantity at this point
I'm getting sick of your stupid comments. 10k? If you don't drive your car all that hard 60,000 is plenty good. You would just be pouring your money down the drain by changing every 10k. Just like the people who change oil every 3000. Get with the times, it isn't 1965 anymore.
Old Nov 11, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
Originally Posted by Huney
Manual doesn't have a filter so all you do is remove the drain plug and drain then replace the oil. Automatic must have a filter and if the filter has contaninants on it you need a flush, if not don't pay for something you don't need. Our Ford says change auto tranny oil every 50K miles but I know guys who went 100K miles with no problems, and they drive hard. Thing is, trans oil has no opening to the outside so no way for dirt to get in but gets very hot so in time probably loses some of it's characteristics. ...
I dont think the auto tranny has a filter inside that needs to be changed. However the drain bolt doubles as a magnent and attracts all metal contaminents in the tranny fluid. The bolt must be cleaned (easily wiped off) before being put back in.
Old Nov 26, 2005
taehoshi's Avatar
taehoshi is an unknown quantity at this point
man, i just drained my old tranny ATF and put in 3 bottles of Honda ATF and what a difference it has made in terms of performance! its almost like how i remember it to be when i first bought the car in late 1999. Before the change, my fourth gear would change at approximately 85 kmph and now its back to normal changing at approx 105 kmph. I can expect a lot of gas saving now since i do most of my driving on the highway to go to work in the fast lane at 120 - 140 kmph. I should of done this sooner!
Next thing will be to go on the synthetic engine oil bandwagon.
Old Dec 5, 2005
jerseydetailer's Avatar
jerseydetailer has a little shameless behaviour in the past
i agree..there is no *magic number* you should look at your driving characterics. and i know ppl who change tranny after a day at the track so 10k isnt a magic number. i like to change mine every year not because i have to but its so cheap..i spend less than $10 per year servicing my tranny so if im wasting $10 a year that ok...and the oil thing...if you do a lot of stop and go traffic or live in super hot climates, frequent 3000k oil changes arent a bad idea
Old Dec 7, 2005
peacebwithyou's Avatar
peacebwithyou is an unknown quantity at this point
Redline
REDLINE tranny fluid all the way!
Old Mar 20, 2006
LC's Avatar
LC
LC is an unknown quantity at this point
how much have you guys paid to get the entire tranny flush ?
Old Apr 1, 2006
HOOCHYboi's Avatar
HOOCHYboi is an unknown quantity at this point
I'm about to hit 60K miles, and I've been driving my car hard since it had like 1,000 miles on it. I'm going to flush now that i've read all this and found out how easy it was. But how many bottles do I need? I'm going to get that Redline stuff.
Old Apr 3, 2006
manual is around 1.5 quarts
Old Apr 3, 2006
civics4everyone's Avatar
civics4everyone is an unknown quantity at this point
Yeah the auto is real tough LOL... ITs exactly the same practically atleast for an 02 civic lx. Both are just drain and fill, no filters or pans. In the manual it says to drain, then refill, drive a short distance then repeat 3 more times. This is for the auto anyway. The auto keeps several quarts of atf in the torque converter thats why you must drain and refill so many times so you eventually get the old fluid out. I would assume the manual transmission would be a little easier but basically the same. Ive heard so many bad things about shops that use a machines to clean trannys. While the flushing is great the fluids they end up with are wrong. They dont use genuine honda ATF which comes highly recommended to do the flush. Yeah if i was HONDA id say use my ATF too but I think theres actually some validity to it. Honda ATF is 6.00 a quart so itll cost quite a bit if you do it like the manual says. my owners manual (has the directions for auto and manual trannys) says replace tranny fluid at 100K, thats seems way too long. I drained and filled 4 times now , 2 times at 30k and 2 times at 64k. The fluid on the dipstick has remained bright red so im happy with that, ill do it again at 90k.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
MajTom
Jun 2, 2015 11:48 AM
usajags84
May 30, 2015 06:49 PM
mrohitredd
May 28, 2015 10:03 AM
bsmiley
Apr 27, 2015 01:27 PM
