Is adding additives to your Eng. good?
Old Jun 19, 2005
49ers's Avatar
49ers is an unknown quantity at this point
Thumbs up Is adding additives to your Eng. good?
Does any body know if if Cmax, Duralube, or Power-up is good to add when changing oil? some old times say don't use additives some people say go ahead, What do you guys think? THX 49ers
Old Jun 19, 2005
i would only trust products from www.lubecontrol.com
Their fp60 gets tons of props from me.
Old Jun 19, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
ok well if you shouldn't really unless the additive is going to do something the oil can't. the oil already has stuff in it to help out the motor. so i would go against it. on the other hand my old buick had leaks in the engine so i used oil additive to stop that. so if you need it go ahead.
Old Jun 19, 2005
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
There are only 2, IMO, that you should trust and use.
LC and AR-X.
They work and are not snake oil.
Old Jun 19, 2005
do you guys remember z-max ith linkite or whatever the hell it was called, and they found out it was only mineral oil? I can't believe its still in stores after all the court cases.
Old Jun 20, 2005
S2000man01's Avatar
O RLY
lubecontrol.com has the only addatives that many knowledgeable people and tribologists trust.
many products out there either are not doing much, or is just thinning out your oil.
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
alexkharden
Apr 23, 2015 07:13 PM
