fuel tank max fill
Old Aug 13, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
fuel tank max fill
Anyone know how much is too much? Cuz I've been able to put about 14.6 in it and it comes up to the fill hole. manual says 13.2 but yeah....
Old Aug 13, 2005
IDQcivic's Avatar
IDQcivic should not be trusted
that seems like a lot of gas, maybe that gas station is ripping you off, try going some place else....
Old Aug 13, 2005
shroomster's Avatar
nah I get it from Sam's club. Wal-mart would NEVER RIP ANYONE OFF.....
Old Aug 13, 2005
streetglower's Avatar
the reason you can put more in then the capacity of the tank is because the company makes the tank bigger for expansion. when the fuel heats up, it expands. Now there is a reason why it says "do not top off" on the fuel stations. For one, you risk saturating the charcoal canister with fuel. Too much fuel is when you keep pumping past when the fuel nozzle clicks.
Here read this:
overfilling your tank can ruin your gasoline-vapor recovery equipment. The recovery canister is supposed to store gasoline vapors rather than release them into the atmosphere. But if you overfill the tank and liquid gas sloshes into the canister, it will stop working, contributing to the formation of ground-level ozone, smog, acid rain, and airborne toxins.
Old Aug 13, 2005
Jrfish007's Avatar
Here read this:
Good info
Old Aug 13, 2005
etdigitalis's Avatar
etdigitalis should not be trusted
HOLY CRAP! I'm never topping-off my tank again!
i've been doing that for years now, so my canister is probably all jacked to hell, huh?
Old Aug 14, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
What does that canister do exactly?
I have been pumping over that cutoff for years, as far as i dare to go, sometimes right to the brim. I like toppin her off!
Old Aug 14, 2005
good thing I only get 1/2 tank normally. You get more gas mileage since the car weighs less anyway. Just fyi, 1 gallon = 8lbs.
Old Aug 14, 2005
in my case, it get's completely saturated with fuel and somewhere down the road ends up exploding in a blazing inferno!
Old Aug 14, 2005
jackburton's Avatar
Kinda like my dads dodge shadow???
Old Aug 14, 2005
the canister stores vapors instead of releasing them into the atmosphere. Its an emissions component, if it stops working, vapors will be released into the atmosphere resulting in smog and basically toxins in the air. And when it stops working, you will be putting out higher emissions. Basically the same thing as the statement I had posted earlier said.
Old Aug 14, 2005
S2000man01's Avatar
O RLY
in other words you could fail emissions. i've even seen some people get a CEL becuase their canister is shot and they have to buy a new one.
not to mention filling "to the brim" is a bad idea. gas can expand.
Old Aug 14, 2005
jackburton's Avatar
Was not sure if you meant it would effect emissions testing or not.
Old Aug 14, 2005
sorry to thread hijack... this is just too coincidental...
wow, that's funny... i had a '91 shadow before and that thing went down in a blaze... well, not really... i was lucky enough to make it to a chik-fil-a parking lot, run inside to steal their extingusher and put it out.
it had a fuel/oil leak under the throttle body that dripped and collected into a pool on the transmission housing... well, when the approprate conditions were met, UP IT WENT!!
anyway, to make a long sory short, i drove it around uneventfully for a couple more days after that before i traded it in for $1650... that and a $250 cash down payment got me my '01 vic.
Old Aug 15, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
if someone else is paying for the gas i can get sit there for an hour topping off
Old Aug 15, 2005
S2000man01's Avatar
O RLY
this looks like 3 different sentences. help me out here.
aside from that, you look like you're saying you top off the tank. read the thread please, and then you'll be educated.
Old Aug 15, 2005
jttegx's Avatar
OMNES AD UNUM
it wouldnt hurt to just top it off with like 50 cents worth would it?
cause i keep the digits straight numbers like $13.50/$12.00/$12.25/etc
Old Aug 15, 2005
that is fine, I do that too. As long as you dont put in an extra $3.00 or so to fill it to the rim of the fuel filler.
Old Aug 19, 2005
2K1Civic17"Gabe's Avatar
yeah, what he said. I always make mine even in the .10. but .25 is fine. just no more than that. I always see people pumping again and again, only to damage their cars. I dont feel I should enlighten them, cuz around here they could enlighten me with a gun, lol.
cukaracha
30
Jul 26, 2015 12:01 PM
Kyles24
Jul 12, 2015 09:15 PM
Jul 12, 2015 11:54 AM
jody501
Jul 10, 2015 11:01 AM
stvpagn
Jul 9, 2015 09:59 PM
