13.2 sux I want more
maybe an RSX gas tank.... everything else seems to fit from those cars. however, i dont know if its any bigger. maybe an accord? I think that u would have to mod something to make either one of these fit though
Originally Posted by AzNmiKex215
We should get around 300+ mile range on a tank. Thats pretty damn good. Its not enough for you? Are you planning to do a Cannonball run? lol
I live in cali. Gas prices suck more for us than the rest of the country. I just want to extend my trips to the pump. I know we get 300+ per tank, but hey 500 would kicka$$.
500... wow.. just thinking about that makes my dreams come true. Well, i have exhaust and intake and i can still get about 330-350 before the gas light comes on, but im on the freeway for about 90% of my driving.. oh yea, cali prices DO suck! but they're going down, it's around $2.57 at the budget stations..
500 mile tanks are doable, depending on your driving habits. My best so far was 504.7 before I chickened out and filled up (took 11.9 gallons).
I'm working on a >500 mile tank right now, pic below was taken the other night when I got home from work; 310.6 miles and just below 1/2 tank.
I passed a gas station today that had 87 octane for $1.99!
yep, I tend to drive at or just below the speed limit. I'm lucky that my commute times are not during rush hour so I tend to have the road to myself and can get away with going just a bit under the speed limit and not causing any traffic jams.
I have an 05 value package coupe (DX with auto and a/c). Tire pressure set at 43 psi, and I used 2oz of FP60 at each fillup. I made a DIY cold air mod just yesterday; I'll be interested to see if that mod affects MPG at all (probably not).
2k1civic.com O. G.
To the people that acheive insanely good mileage on one tank (350+) Do you have large rims and bodykits?
I blame my low 250-300 Miles Per Tank on my Kit, Trunk System, and 18 inch rims. I guess all taht weight is taking its toll?
haha no i was talking about the weight of gas. 1 gallon = around 8 lbs i believe so 6 gallons = almost 50lbs. that makes a difference.
my gas light comes on after about 410 miles.....i know something is wrong if i don't get past 400 miles, the last time i didn't get that was because i needed a new air filter...............oh and YES 18 in rims will suck a lot more gas!!!!....
Originally Posted by gearbox
i rarely fill past 1/2 so less weight= better mileage.
make sure your tires are filled up to the max, more tire pressure means smaller conact patch and less rolling resistance. You should also get tires that last a long time or high milage tires, they are often harder and have lower coeficient of friction. Of course all this will hurt your handling if you loving blazing through corners.
It helped greatly on my truck, Ford filled the tires to 40 psi, and I pumped them up to 60 psi and gained about 1 mpg (1 mpg is big gains for a truck
). And yes, the factory tires are deisnged to handle up to 65 psi, so no I was not out of spec, I want to go to 65 psi, but the air pressure at the gas station only went to 60
BTW, the ride does get a little rougher at higher tire psi.
Ahh yes, as far as gast tanks go, my truck has a 39 gallon tank and I get about 600 miles out of it before I have to fill up about 31-32 gallons. I have a hualing truck that has a 75 gallon tank of diesel in the bed and 35 gallon tank, I know an aftermarket company put the larger tank, I just forget who, but I know somebody out their makes DOT approved after market tanks.
im passed half a tank right nwo after a fill up with a top off and i think i just hit 200 today..............OUCH!!!!
but ive got 17's drive pure city crap through boston heavy traffic, and have a heavy system and a fat friend i commute with to and from school 15 miles everyday. plus its standard so coming from a stop hurts also especialy with all this weight.
Crayons taste like purple...
lindermant you might want to check your max p.s.i on your tires...overpressurizing tires (most car tires have max of 35 or so) can cause separated belts.or instant blowouts when and if you hit a piece of debris or pothole,(not a flat tire a blowout where you lose control or that quarter of your car is demolished by the tire). tis better to get safely from point a to b with 35 mpg than to risk your life saving $5 a tank.....
