Best Place to Jack up front of car...
Old Jul 26, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
and to put 2 jack stands in front...what would be the strongest point from the front of the car, cause i dont want to wiggle on the sides putting each side up...
and for those of you with 5mt, did you put something like stoppers on your rear wheels just in case?
Old Jul 26, 2005
Honda_trilogy's Avatar
Honda_trilogy is an unknown quantity at this point
Try that the ridge there runs from front to back. It has to be strong enough to support the car when it's put on racks. Just take it easy and you won't bend anything.
Do one side at a time.
Old Jul 26, 2005
nah it bends very easily...there has to be a place toward the front of the car that is strong enough, such as the tow hook?
Old Jul 26, 2005
did it bend on you? I haven't had that happen yet.
Old Jul 26, 2005
robbclark1's Avatar
Retired suspension supermod.
you jack at the jack points and use the ridge along the side of the car. It should not bend, except at the edges near the wheels.
Front of car Rear of car
Wheel - jack - jack stand jack stand - jack - wheel
Old Jul 26, 2005
sounds like a good method.
The V in the stands will keep the ridge from bending unless you really screw things up.
Old Jul 27, 2005
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
There's a center jack point in the front of the car. Get under the car and you'll see an arrow on the plastic that points directly at it. It's right in the middle, maybe 1.5 in by 3 in. Jack from there, put the stands under the jack points that robbclark documented, and drop the jack.
Old Jul 27, 2005
Al Gore FTW's Avatar
jdmtytedoridori
^hes right
Old Jul 27, 2005
What do you know... I just went out and checked and there is a center jack point.
Old Jul 27, 2005
thank you! i knew there had to be one!
Old Jul 27, 2005
slicksivik's Avatar
can i jack the back up where the tow thing is? my car is so low and with my sideskirts on i cant jack the car up on the sides at all cuz there so low and theres no place to jack them up, even if i ride up on boards.
Old Jul 27, 2005
I don't know how could of an idea that would be. The tow hooks are made to be put into tension, not compression. The shear values may be harmful.
IOW, they're made to be pulled on and not pushed on.
There has to be someone here that can help you get around that.
Old Jul 28, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
It's strange then how Honda specifies the tow hook as the rear jack point...
I always jack up the back as described HERE.
Old Jul 28, 2005
Yes! That is a much better way to jack up the rear!
Also, if Honda does specify the rear tow hook as a jack point then it must be good. They know the shear values the hook will recieve when put into compression like that.
I would still rather do it they way your illustration showed. That's a reall beefy area with nothing to worry about.
Old Jul 29, 2005
robbclark1's Avatar
ok
1st off, use the OEM jack to get the car high enough to jack up the car with the real jack.
Secondly, you CAN use the tow hook as a jaking point, however, if you have a little jack, then they usually DO NOT go high enough to put stands underneath.
Old Aug 1, 2005
2K1Civic17"Gabe's Avatar
I use the point in the front, works fine. I use th ehook in the rear, works fine. Ihave to use the oem jack to get the car up high enough for the real jack though. My car/IC is too low. Than pop the jackstands under there, and drop the car slowly.
Old Aug 1, 2005
MiamiUgen7's Avatar
just an fyi, dont do it on the radiator support, that bends :-/
Old Aug 1, 2005
robbclark1's Avatar
I guess you speak from experience...sucks for you...:-)
Old Aug 2, 2005
yeah, that sucks, hehe
at least Ive never attempted that. I use the jack point.
Old Aug 2, 2005
MiamiUgen7's Avatar
yeah, i bent it back in place, but not a good jack point. is that bar that runs under the side of the car ok to use as a jack point?
GolNat
Suspension DIY
May 12, 2022 06:49 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
GH04si
Apr 15, 2015 08:13 PM
Grey
16
Jan 27, 2002 11:34 PM
popsiclepete
Canada West
Dec 1, 2001 02:04 AM
