engine oil question
Old 07-31-2005
return_2020's Avatar
return_2020 is an unknown quantity at this point
engine oil question
03 civic with 42kmiles. Here is the question. My car is running fine but i noticed something strnage today. i do my own oil changes and put 3.7qt every oil change with filter. and today when i drained the oil,it was kinda low. because i poured the oil in the milk gallon and it was not totally filled to the top. this way i know its excatly 3.7qt. now this is the first time i had my oil change done at 4000 miles. i usually do at 3000 but this time i had driven for 2500 miles on long trip for 3 days. and noticed it was little low.Is it ok for engine to eat little bit of oil ? i would say it was kinda half a quart low. also i changed the oil to exxon superflow and didnt find any metal in the oil. otherwise i used to notice them in my castrol oil. please put suggestion on this.
thanks
Old 07-31-2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
If you drove it extremely aggressive then i would say alittle gone would be ok, maybe you didnt totaly tighten the draqin plug and it leaked alittle bit without any notice.
Old 07-31-2005
OMNES AD UNUM
jttegx's Avatar
if your still running on that same oil, im sure you could add onto it? as long its the exact same motor oil.
but theres something about highway driving and motor oil that i dont get, i really dont know. oil drain plug tight?
Old 07-31-2005
O RLY
S2000man01's Avatar
burning a little oil is no biggie. hondas do tend to do this, some more than others. (S2000's can burn a quart in as little as 2000 miles)
Old 08-01-2005
hmm my car doesnt burn any oil, but my old 99 dx did sometimes if i drove it hard which i normally did
Old 08-02-2005
TSSCivic's Avatar
TSSCivic is an unknown quantity at this point
Losing a little bit of oil is okay especially if you drove it hard. For some reason a lot of Honda engines burns a little bit of oil especially if it's been driven hard.
Old 08-03-2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
beter oil then something else
Old 08-03-2005
Jrfish007's Avatar
It's normal, Every Honda I've had has done it.
Old 08-03-2005
Narfcake's Avatar
Narfcake is an unknown quantity at this point
Originally Posted by return_2020
... because i poured the oil in the milk gallon and it was not totally filled to the top. this way i know its excatly 3.7qt.
1 gallon = 4 quarts, so 3.7 quarts would not be totally filled.
Also, are you taking in consideration that the oil filter and oil filter media is still holding some oil in?
-- Kane
gearbox
Electrical DIY
72
11-27-2015 08:13 PM
amrhamed
06-01-2015 08:08 AM
BootyDo
05-07-2015 04:46 PM
Grey
16
01-27-2002 11:34 PM
Grazzhopper
11-11-2001 08:06 AM
Quick Reply: engine oil question
