Amount of oil
Rep Power: 0 Amount of oil
This is one hell of a noooobb question and i feel like a dumbass asking it but i lost my owners manual somewhere. How much oil do our cars take with a complete oil and filter change in a 02 civic ex 5 speed.. i think its around 4.6 but i cant remember correctly
thanks in advance
thanks in advance
Rep Power: 0 I put about 4.5. But I am turbod, and have extra lines and parts for oil to flow through. Stock is between 3.5-4.
4 quarts always worked good before i was turbod. it went right to the twist in the dipstick where it should be.
OMNES AD UNUM
Rep Power: 309 03 ex auto.
manual says: 3.7 qt and thats if its FULLY drained meaning to the point where the motor is flushed cleaned.
when i change my oil and oil filter, its about 3.5 or 3.6 in most cases.
remember, its always better to fill less cause if you overfill, you would have to remove the oil filter to take out the overfill amounts. so fill around 3.3 quarts and keep checking the dipstick. and the engine would suffer if you just turn it on for awhile while theres only 3.x quarts in there. just a tip
Turbos, Engines, Chassis and Suspension Tech
Rep Power: 0 Why would you have to take off the filter? Just take out the drain plug. And I usually put 4 in. .3 qt is not going to affect it that much for me to justify having a small amount in a bottle sitting on a shelf.
1 Post
Originally Posted by mclean987
can someone tell me what it says for the 5 speed tranny ? how much quarts?
Rep Power: 0 I usually fill up with about 3 1/2... Start the engine, let the filter fill up and then shut the car off, check the level again, put whatever it needs to reach the full mark.
Rep Power: 0 no its alot mroe they say to fill it until it overflows it has to be atleast 2.3 quarts-2.5qts.
Originally Posted by Storm897
DIY Manual Transmission Fluid change. I think its about 1.6 or 1.7 quarts.
Drunken Master-7thgen Ninja
Rep Power: 312 yeah thats from the manual. don't drown your tranny. btw its for a dtick tranny not auto. i have no clue about autos. does your car still run after putting in 2.5/3? cause if its a stick it shoudln't run. if its an auto it shouldn't run either.
1 Post
I'll checked the Honda Service Manual once I get home, but I am 100% sure its somewhere around 1.7 quarts.
Rep Power: 0 well i put 3.7 qts. drain put in 3 1/2 then slowly our the rest put the cap on crank car let run for a minute then check for leaks and dipstick for right amount of oil. it should be right at the top hole on the dipstick. 3.7 if you are changing the oil filter at the same time. maybe like 3.5 without oil filter change, but i change the filter every time.
Rep Power: 312 i put clean oil in the new filter. like 1/4 full of new oil in the filter that way the motor doesn't start up dry. well not all dry but you guys know what i mean. anyway it helps.
honda.lioness
08-06-2015 11:58 AM
suburbanite
07-17-2015 03:05 PM
