oil filter
Old Aug 20, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
oil filter
i been having problems removing my oil filter when it's time to change my oil it's getting so tight that i have to put a hole in the filter with a screw driver to remove the filter. Any idea's ?
Old Aug 20, 2005
streetglower's Avatar
yea by an oil filter wrench. there are several styles out there to choose from. Or otherwise by a pair of channel locks and twist the filter off.
Old Aug 20, 2005
I tryed 2 different types of oil filter wrenches, neither worked. using channel locks work's great, but the filter get's mangled.
Old Aug 20, 2005
Jrfish007's Avatar
if you're removing the filter who cares if it's mangled?
Have you tried the filter arench where you connect a ratchet to it, that's my favorit for the civic because you don't ned much room.
Old Aug 20, 2005
who cares if the filter gets mangled, you arent going to reuse it again.
Old Aug 20, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
This is the filter wrench I use. Its works great. I no problems taken off oil filters.
Old Aug 22, 2005
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
Yeah yeah I know, if the filter isn't tight it's going to either leak or fall off thus ruining my engine. Thus, people really overtighten them thinking it's the one bolt/gizmo that needs to be tight otherwise the car falls apart.
That's the number one reason for people think it's OK to really tighten the filter. If you're pounding a screwdriver through to take it off it's too damn tight.
Just follow the instructions that every manufacturer puts on the can - 3/4 a turn after the gasket makes contact.
Old Aug 22, 2005
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
I bought a cheap metal ratchet-type filter wrench from Wal-Mart. 20+ changes later and I've never had a problem changing the filter.
Old Aug 22, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
if you don't already, you need to put a little oil on the threads and lip before you screw the filter in ...
Old Aug 22, 2005
isuzu5000's Avatar
isuzu5000 will become famous soon enoughisuzu5000 will become famous soon enough
maybe you should start working out
Old Aug 22, 2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
yellow kitchen rubber glove, clean the oil filter and that thing will grip to it easy
Old Aug 22, 2005
jttegx's Avatar
OMNES AD UNUM
^but you'd have to wait like an hour cause of the heat. thats if you run the car for awhile then start changing the motor oil that is, which is how its suppose to be done.
how much does walmart sell oil filter wrenches for? what kinds do they have?
Old Aug 23, 2005
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
too many ppl over tighten the oil filter i swear...just like flashlightboy said...only suppose to turn it 3/4 turn or one whole turn and no more. that's why there a gasket there to keep it seal with no leaks
mistermenphis22
Jul 13, 2015 04:43 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
stvpagn
Jul 9, 2015 09:59 PM
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
