How Do You Change Manual Transmission Fluid
Old Mar 26, 2005
john_817's Avatar
john_817 is an unknown quantity at this point
Exclamation How Do You Change Manual Transmission Fluid
I read the DIY on how to change ATF but im wondering how to do it on a MT. im also confused on where would you pour the new fluid into (location). is there anything special tool you need?
thanks
im wondering because shifting isnt smooth anymore and also when cruising on the highway 5th gear pops of gear and into neutral after a period of time. so im hoping this new MTF would do the trick.
Old Mar 26, 2005
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
DIY
Poping out of second and fifth is a defect in your transmission. Honda knows about the problem. Go to the dealer and bitch them off. They should repair it at no charge. If they give you trouble for warranty being up, bitch some more. There is a TBS recall for it, Can't find it right now.
mattdoc
Mar 14, 2017 12:10 PM
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
cruisers10
May 12, 2015 10:46 PM
bsmiley
Apr 27, 2015 01:27 PM
