Is anyone running the DSM "Blue tops" 450cc? - Honda Civic Forum
Old 09-28-2005
Just wondering if there are fitment issues. I know I'll need to lengthen the rail studs but is that not enough?
Rufus is offline
Old 09-29-2005
Abortion Survivor
Michalo187's Avatar
those look huge I think there would be problems because they are to fat to go into the holes and then you will have clearance issues with the tps
Michalo187 is offline
Old 10-05-2005
cberman is an unknown quantity at this point
I have them in my 6th gen...at least for me, to get them to fit in the intake manifold, you have to take a dremel (the red cylindrical sanding thingy) and bore out the intake manifold seal a bit...u will most likely also need a different injector connector (obd 0 and obd 1) should fit...you will also need to use an resistor box
cberman is offline
Quick Reply: Is anyone running the DSM "Blue tops" 450cc?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
