What kind of Oil to use
Old Aug 6, 2005
Ruamit03's Avatar
Ruamit03 is an unknown quantity at this point
Hi guys, I just recently bought myself a 03 civic, and it's certified yet when I checked the oil it was really dirty. So I am going to change the oil but not use what to use. The car has about 16k on her right now. On the oil cap it says 5W-20, wouldn't that be too thin, I was thinking Maybe mobile1 5w-30 or 10w-30. What do you guys think. Thanx for the help.
Old Aug 6, 2005
jttegx's Avatar
OMNES AD UNUM
5w-20, no its not too thin for that motor.
i guess driving habits and climate is also a factor?
i fill up with 5w-30, its pretty heated here in CA lately and my driving habits are spirited rather than granny.
but cant go wrong with 5w-20. there could be downfalls using 30 weight
Old Aug 6, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
the car is designed to run on 5w20 or 5w30, i wouldn't put anything else in
Old Aug 6, 2005
Jrfish007's Avatar
Honda wouldn't screw you, put 5w20 in if you are in a place that is can get cold, if you are in the desert or something, 5w30. Ford's also use 5w20, it's not to thin if the engine tolerances are tight. Not only that, 10w30 will slowly deprive the bearings because they are designed for 5w20 and this will shorten the life of your engine. It will also cause emmision problems down the road.
In short, the car is made for lighter oils (they give better MPG and are cleaner), so use lighter oils.
Old Aug 6, 2005
Ruamit03's Avatar
New I am in the Tristate area, so during summer its usually 90+ and during winter it's around 20. I guess i'll stick to 5w-20.Thanx
Old Aug 6, 2005
Jrfish007's Avatar
No problem, and welcome to the site
Old Aug 6, 2005
S2000man01's Avatar
O RLY
yup go with the 5w20. can't go wrong with manufacturer's recommendations.
Old Aug 7, 2005
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
I would use the 5w20 til the warrenty runs out. After that you can stick with the same or bump up to 5w30. Give Chevron or Havoline oil a try, it's one of the top non-synthetic oils out there.
Old Aug 9, 2005
Ruamit03's Avatar
These motors take about 4qt's right. Sry if it's a noob question, but just wanna be sure.
Old Aug 9, 2005
streetglower's Avatar
actually 3.7 quarts to be exact.
Old Aug 11, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
you sure streetglower?
Cuz I have checked repeatedly with the dealership and my QuakerState fluids manual and it says for the D17's 3.2 or 3.5 vtec and non-v-tech? but then again is 6.4 oz. gonna make that much diff? (3.7-3.5 qts. = about 7 ozs.)
NOt flaming ya I just want to make sure I'm filling up right at my job and not potentially screwing the seals
Old Aug 11, 2005
gangrel138's Avatar
gangrel138 is an unknown quantity at this point
If you accidentally overfill just a little it won't hurt the engine. My oil of choice is Royal Purple 5w30. If I don't drive like Mario Andretti all the time I usually get 35-36 mpg city.
Old Aug 11, 2005
messiah's Avatar
messiah is an unknown quantity at this point
mobil 1 supersyn 5w20 or idemitsu 5w20
Old Aug 12, 2005
Jrfish007's Avatar
if you are changing the filter too, 3.2 quarts for the DX/VP/LX, 3.5 quarts for the HX/EX/SE
3.7 is safe bet because you may burn a little oil, 3.7 will give you a little extra room.
Source:
http://www.hondanews.com/CatID2015?m...43094&mime=asc
Old Aug 12, 2005
Jrfish007's Avatar
Good stuff
To bad it's $6 a quart
RIPSAW
Nov 6, 2015 04:36 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
civiic143
Jun 29, 2015 06:15 PM
Tim1959
Jun 3, 2015 08:15 PM
wawacito
Dec 14, 2001 08:52 PM
