60k questions, save me from honda dealers
Rep Power: 0 60k questions, save me from honda dealers
guys,
sorry ive searched but still not satisfied, im about to DIY my 60k maintenance of my AT sedan($389 fee on my local honda), here are the things im about to do & need your help & corrections
1. transmission fluid change
buy 4 quarts from honda, drain then refill
should i do it once or three times as the manual says?
any pix where i can find the bolt? it doesnt show on my manual
2. brake fluid change
buy ATE superblue, remove bleeder valve, catch the old brake fluid w/ hose & pan, have someone pump it slightly while continously topping the reservoir w/ the new fluid until i see the blue fluid coming out of the bleeder w/c means the old fluid is gone
3. change oil & filter
4. change air filter
5. change dust & pollen filter
how about the power steering fluid? when should i change that?
when should i change my brake rotor?
when should i change my shocks?
please make any corrections & help is appreciated
thanx
thanx
Originally Posted by zackde
guys,
thanx
thanx
Now the way you just described to do your brake fluid, you will have lots of air in your system if you do it that way. You cant just have someone pump the brakes waiting for new fluid to come out. You need to start with the bleeder valve farthest from the master cylinder, have someone pump the pedal a few times then slowly push it in, then open the bleeder for a second then close, then have the person let off the pedal. That way no air is let back in. repeat this 5 times or so, and move to the next wheel untill all 4 are done.
Power steering fluid, just suck the old fluid out of the resovoir and add new fluid in. Now the shocks and brakes are basically done/replaced when needed, so check your brakes.
Rep Power: 0 When should I change my power steering fluid? It doesnt says on the manual when should I change it only says I should TOP it.
How many quarts do I need for brake fluid replacement?
Rep Power: 265 i wanna learn to DIY oil change and tranny since im coming up on 15k here soon.
and i can aford to pay honda.b ut would rather door little things like tha tmyself. like changing the oil. i just need to learn mroe abotu where to put the new tranny fluid in. i know where the oil goes
wuts the BEST oil and best tranny fluid for our cars?
also is a radiator flush a good idea come summer time?
Xuhme
21
08-07-2023 03:40 PM
CarStuff
12-06-2020 12:52 PM
jakeconnor
05-05-2015 07:30 AM
jessicakaybby
04-20-2015 12:11 PM
2005, 60k, brake, change, civic, dealers, fluid, fluids, flush, honda, maintenance, maintenence, quarts, shocks, transmission
