Civic takes a while to start then shuts down
Old Nov 3, 2007
matrixmonk's Avatar
matrixmonk is an unknown quantity at this point
Hi all great forum.
My 1990 honda civic shut off on me just as I stopped at an intersection. When I try to start, the engine tumbles for a little while, then finally starts rough, and as I start to accelerate it shuts off, its like its losing power. I changed the plugs, wires, distributor cap, rotor and still the same.
Could it be the fule pump, filter or relay?? Please help anyone. Thank you.
Old Nov 3, 2007
Re: Civic takes a while to start then shuts down
possibly low fuel pressure, maybe a clogged intake system or idle air valve/tb/fast idle thermo valve depending on what you have. idk, try cleaning out the intake system parts, then get a fuel gauge and check the pressure.
Old Nov 3, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
EGR or PCV maybe?
just shootin ideas....
Old Nov 3, 2007
lordhelmet's Avatar
Check the fuel pump relay
Old Nov 4, 2007
mauri503rida's Avatar
mauri503rida is an unknown quantity at this point
Thumbs up Re: Civic takes a while to start then shuts down
85 % percent of the times whan your car starts doing this kind of crap is the fuel pump relay or the bypass valve .the fuel pump relay is in a very facking hidden god i hated it when it happened to me that relay is right behind the little handle that you use to open your hood and it will look kinda like this .
http://www.autozone.com/selectedZip,.../selectZip.htm so good luck hope you get it fixed .
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
civic_gt
Apr 19, 2015 08:15 AM
smmahan
Apr 15, 2015 08:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
