Faulty Brake Light- 99 Civic EX
Wondering if anyone can help...
Have a left brake light that goes out when brakes are pressed.
Replaced fuse and bulb with no change.
Tail-light works fine when lights are on but tuens off when brakes
are pressed. Only on the left side though...???
Is there a relay that I can replace or could it be a problem in the harness itself?
Thanks for any input.
Mike
Mike
Re: Faulty Brake Light- 99 Civic EX
prolly an issue with the bulb socket. if you push the bulb too far, the contacts will short out. try pulling the bulb out a tiny bit after pushing in. if it lights up, theres the problem. make sure that the metal wires bent at the bottom are not sticking out at all. you can use a screwdriver to carefully flatten them if they are. theres supposed to be a lil knub at the bottom middle so it doesnt go in too far, but it doesnt always work. i had the same issue with a front signal bulb.
Thanks for the tip. Worked like a charm. Two working brake lights now!
I appreciate your time.
Mike
Mike
Xuhme
21
Aug 7, 2023 03:40 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
