Big mistake, Bigger problems, need your help!!!
Rep Power: 0 Big mistake, Bigger problems, need your help!!!
Ok, so as stupid as this is my brother, the idiot, recently was driving my 2001 civic DX for the night and he ran out of gas. So, he and his buddy grabbed a gas can from the garage, unfortunately, the can had about 3-4 gallons of diesel in it. My brother drove the car less than a mile before it started acting up and stalled.
We discovered the problem in the morning, and imediatly got real gas, 87 octane, and put about 2 gallons in and tried starting the car. However, smoke started coming out the exhaust and the engine would not turn over. Then the dash lights and gauges would start flickering and eventually go off when we kept trying to start the car. Once I would stop trying to start the car all the gauges would flicker and click for a few seconds before completely shutting off.
I need help figuring out what to do?? I am leaning towards taking the car to the shop to have the fuel line and tank drained but would love to avoid this.
Please let me know why my gauges and lights would be effected and go so hay wire??
P.S.- We also got more gas, 93 octane, and added about 5 more gallons as well as octane booster, in hopes to at least get the car started, but no luck.
Please help!! i really dont know what to do or what kind of problem iam looking at!!!?????
Rep Power: 0 Re: Big mistake, Bigger problems, need your help!!!
just stop adding gas when they have diesel in the tank.because you wont be able to use the gas in your tank anyway. you will have to get it dained. no questions asked. as far as your dash lights flickering i would have to see it to answer that problem because we dont know alot about your car.
Rep Power: 220 Re: Big mistake, Bigger problems, need your help!!!
yea gas and diesel dont mix. the gas just floats ontop of the diesel b/c it's lighter. kinda like gas and water.
if u have a big enough container u could dissconect the fuel rail, diisable the starter, and hold the car in crank to pump out the tank. it will take a while but what other choces do u have?
oh and dont let him drive the car again.
Rep Power: 232 Re: Big mistake, Bigger problems, need your help!!!
damm is he slow or what kick his dumb ***. i was at the gas station yesterday and this lady filled her tank up with diesel and then asked me if that would work. luckily there was a garage there. isn't the diesel nozzel bigger so you can't do that ???
Rep Power: 210 Re: Big mistake, Bigger problems, need your help!!!
get the tank drained for sure and the light were most likely flickering like that because your battery voltage was getting low from cranking the car a lot. the starter drains a lof of power from your battery, so put a charger on the battery, get the tank drained and take it from there, just hope you didnt mess up your injectors.
down here the gas side is the black nozzle and you select you grade and the diesel is the green one that says DIESEL. someone just dont read the pumps before they put gas. they must have a special edition civic with a f-250 turdo diesel motor in it. and dont get mad we are just kidding we wouldnt want that to happen to our civics. you could do the old fashion way. get a thin long hose and put it down in the gas part and suck on the end of the hose a cife the gas out. but you will need alot of tic tacs after because you will have diesel/gas breath. yuck
Rep Power: 228 Re: Big mistake, Bigger problems, need your help!!!
Yea whatever u do a complete drain is the best way to go. And as mentioned above ur battery is probably dying thats why ur lights are coming on.
1 Post
Rep Power: 328 Re: Big mistake, Bigger problems, need your help!!!
FAIL.
just like the idiot who added NOS energy drink to his gas tank
http://www.gixxer.com/forums/showthread.php?t=226570
FAIL.
LOL, reminds me of the time I stopped at the gas station, filled up, then looked at the pump again. Turbo Blue??? Oh ****!
Later found out, after my partner called the gas station, that they use that particular pump for TB part of the year and regular the rest of the time (and I had indeed put normal gas in my car). Hence why it's double-labeled as both TB and regular 87-octane (and hence my confusion--"but it says 87, then it says Turbo Blue really big, and the price is the same as the 87...uh...what did I just do to my car??").
My partner said that the guy he talked to on the phone sounded like this was nowhere near the first time that had happened. You'd think that would signal them to not use the pump for two purposes, but apparently not...
7thgensurvivor
38
08-29-2015 11:50 AM
