Replace O2 sensor, now engine hesitates
This is my first post, and I hope I have it in the correct forum. I couldn't find an answer to quite this exact problem.
My 2000 Honda Civic EX check engine light came on, Autozone read the code: O2 sensor circuit low voltage (bank 1, sensor 1). I replaced the forward sensor, before the catalytic converter with a Bosch universal oxygen sensor.
Cleared the check engine light by removing the backup fuse for 10 seconds.
The check engine light is now off, and the car runs fine except for the first 10 seconds or so. Every time I start out the car hesitates. I give it more gas, it hesitates once, maybe twice, and then it runs OK.
Any help would be appreciated! Thanks.
Re: Replace O2 sensor, now engine hesitates
shouldve gotten the bosch OE type sensor that you plug in. the universals usually always cause issues.
Its the universal 02 sensor... Same **** happened to me, just buy the ones that have the same connector as ur stock 02 sensor. I got both up and down stream from pepboys..
^ Its the same design, just not a specific part number that relates to the exact car its supposed to be in- probably has pig tails you need to splice into the existing wire instead of a honda type connector that just plugs in.
Thanks for all of your help. Advance Auto said they would take the universal O2 sensor back, so I ordered an OE sensor from Honda and it works fine. No hesitation at all.
BootyDo
Jun 21, 2016 03:45 PM
suburbanite
Jul 17, 2015 03:05 PM
mistermenphis22
Jul 13, 2015 04:43 PM
CivicsClass101
Jul 9, 2015 11:14 AM
