60,000 Service for Civic - suggestions
Old Mar 25, 2009
want2xpress's Avatar
want2xpress is an unknown quantity at this point
Hi There,
I'm planning to do a 60,000 miles service for my Honda Civic 2000. Our dealer is offering service at $388 (it says regular price is $488). Plus any extra charges for parts to be replaced.
Is it a reasonable price?
Also do you have any references where I can do this service here in Bay Area (East/South Bay).
thanks,
W
Old Mar 25, 2009
Re: 60,000 Service for Civic - suggestions
what all is getting done tho?
Old Mar 25, 2009
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Ok for starters no price from the stealership is reasonable, unless its free. I would check all fluids, and belts. Feel free to examine/change your O2 sensor and spark plugs. Might need new tires. I'd do an oil change and trans fluid change. Just change the trans fluid, don't flush it. Also look in your book, it should say what needs to be inspected at 60,000 under the maintenance section. The only time you might ever consider doing it is if you have the extended warranty. They like to not cover stuff if you fail to do the maintenance. Otherwise just do what I said and you should be good to go.
Old Mar 25, 2009
Thanks for the replies.
I've checked with dealer and they says that as per Honda Civic Owner's manual they will do the servicing. Now you may call me idiot as I haven't read the manual yet.
So going back to my question: if I've to get the professional help (as you can see my knowledge with car here), how much would be reasonable cost?
Also any recommendiations to get things done?
I found this discussion forum through google. I'm just upset why I didn't do it early.
Thanks again for your expert comments,
W
Old Mar 25, 2009
depends what needs to be done at 60k. usually trans fluid is every 30k, coolant may need changing, brake fluid if its been 3 yrs since the last flush, engine oil maybe, spark plugs, air filter, cabin filters, battery, it all depends what youve already done recently.
Old Feb 19, 2010
hurtingbad's Avatar
hurtingbad is an unknown quantity at this point
I called the dealer and at 60,000 miles all they really do is inspect the car.They said they change the cabin and air filter,that is easy to do yourself.Change transmission fluid.All that is drain and fill.They want $325.00 for that.I don't see what all the money is for.
e
Old Feb 19, 2010
they might need a new plasma tv for the lounge
Old Feb 19, 2010
97EK's Avatar
97EK will become famous soon enough
Lol, so true.
Most of the time, the dealer is just gonna take you for a ride. Unless there's something terribly wrong with your car, just do the basic maintenance stuff yourself (spark plugs, oil change, check battery, etc...)
Old Feb 20, 2010
its getting crazy at the local dealer here. $125 for spark plug replacement (diy=$10), $85 for air filter (diy=$15), etc
Old Feb 28, 2010
eLChiCho25's Avatar
eLChiCho25 is an unknown quantity at this point
My dealer wanted $75 for Synthetic oil change, ($35 for reg oil), $99 to replace the Cabin filters...
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Xuhme
21
Aug 7, 2023 03:40 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
GaryFishell
Apr 24, 2015 06:49 PM
bo_red
Apr 23, 2015 10:09 PM
