- ANy alternator deals?
- buying tail light
- thinking bout a d16y7 block with d15z1 head
- D17A2 head replacement. Head bolts?
- Tie-Rod replacement?
- Searching for DIY Oil Change (Auto tranny)
- need tips to jack tranmission from ground back to engine
- Wiper blade replacement
- GReddy Informeter Touch
- quick flywheel/pilot bearing question
- 2001 lx 5 speed bearing woes
- looking for Radio code
- 1999 Honda Civic 285k miles Warped rotors? -- help!
- 2004 Honda Civic DX - CLUNKING noise?
- rear bumper and tail light housing replacement
- b18c tranny seal leak! i need a solution.
- how to drain/fill the automatic transmission fluid on a 2002
- 93 civic dx body swap
- timing belt check
- How do I remove everything to do with cruise control?
- adding tach.. ebay?
- Radio code
- Interior cloth separating from plastic...
- Where to buy a timing belt/water pump?
- due for a clutch job.. flywheel advice needed
- How do I install acuators?
- fan switch
- manual transmission fluid change
- Valve TDC question please. Thank you.
- help....ls vtec wont start........
- Dealer trying to screw me on AC???
- WTF?! B20c?! WTF?!
- what's a fair asking price for ctr cams?
- LOL @ eBay Chip Fail HAHAHAHA!
- checking ecu cel is solid no blinks
- Random overheating, 2005 Honda Civic LX
- kill switch wiring help needed
- New To Honda Scene. What Is The Differences Between Honda Civic EP2 and EP3?
- Input shaft bearings
- 04 honda civic engine swap possible
- VSS 1997 Civic
- DIY: Intake & HID
- help with 97 civic idle prob
- 02 civic si door panels into 02 civic ex coupe
- info
- Linear solenoid??
- painting honda emblems
- 1996 DX Sedan engine problems
- Front Lowering Springs Problem
- 04 ex exterior handle
- 2004 Shaking and Starting Problems.
- PLEASE HELP! my car is self destucting!
- window problems
- Are 93 2 door and 4 door windshields the same?
- Can't get my idle right
- NOOBISH question on nitrous
- vetc oil pressure Problem
- SC300 vs SC400 vs 944 Frankenstein
- quarter panel rust
- wheel alignment specified ranges '02
- help needed- motor mount problem
- Help with prepping my side skirts? =]
- DIY Crankcase Air Breather
- Ecu
- EF2 twin carb
- A ghetto fab catch can question
- Head gasket question
- breather chamber hose disconnected-what damage could have been done?
- 2005 Civic EX Upgrade Help
- Pros and cons of different valves?
- 7th gen lx/ex exhaust conversion questions
- 2010 civic coupe interior bulb sizes
- 6th gen driver window motor question
- speedo
- timing belt job... water pump is leaking slowly
- Overdrive Question
- 2001 civic intermediately runs rough
- JACK STANDS, some questions...
- 1992 civic hatch hood stuck
- 5th gen civic crank bolt help needed
- Painting Rims/Interior
- Please help with my 97 civics audio...
- 96 honda civic
- Dealer Spark Plugs (DENSO) question.
- Where is VSS on a 5-spd Gen 6?
- Replace Tail Light Assembly on 02 SIR
- Realigning Door
- Gas cap.
- hard to disconnect green 4P connector to alternator
- oil in intake
- 04 civic growling rear brakes.....enough
- Molded grills and difference between models
- Timing Belt Change, 2nd time around.
- I need a K series crash course
- clutch help!!!!!!!!!!!!!!
- 2005 Honda Civic Air Conditioning Evacuation Procedures
- A/C Evacuation Procedures for a 2005 Civic
- Help, AC question
- Simple stereo question?
- Transmission drain plug
- 07 si spark plugs
- powerbuilt harmonic damper tool
- thinking about it..... 1st job, should I go for it???
- New rotors & cv axle...
- Diy cai
- Wiring nightmare
- dash indiglo face for 7th gen
- Wheel wobble and a shimmy shake
- adding sirius radio
- 1994 civic ex swap?
- E3 spark plug change?
- mpg cold vs warm weather
- Did I flood my engine?
- Hheellllppppp!!!!!
- Built D17a2 with boost!
- DIY Center Armrest Removal
- how to grease bushings
- Turns but wont start after head gasket job.....
- AC help
- trailer hitch for civic
- Chrome peeling - Interior door handles
- advice for high speed stability
- header install and mpg?
- Best Clutch for 1996 Civic HX..?
- Help with installation of underglow on 01 Civic?
- Wind shield wipers are gay
- trying to check power steering
- Civic 04 Diesel - cutting out
- Camshaft position sensor malfunction issue
- advancing ignition timing- is this the correct mark?
- 2000 D16Y8 o2 Sensors
- antenna install - can't find under dash lead
- Question about installing a header
- Sticky throttle cable.
- clean brand new headlight bulbs?
- siezed head need advice
- brakes- do you really get what you pay for
- Can you use a d16 starter for a d15 motor?
- Steering wheel always tilted! :S
- new injectors
- need help- fuel system too lean bank 1
- Accessing the washer fluid resevoir tank on an '05
- Need help with replacing MCU/Fuse box wiring diagrams would be usefull
- Civic Side Skirts
- Alternator, '98 EX
- Whining noise during acceleration.
- slow accelerations in high gear
- HELP! CIVIC is not getting very HOT!
- Undercarraige maintenance..
- Hazards not working????
- OHH SH#@! I think i ****ED UP!
- Camshaft Position Sensor Location
- Tail light turns off when braking
- lc fp60 or fp plus
- RE: Crankshaft position sensor help required
- air filter
- Any Remote Starter recomendations?
- adjusting ac belt tension adjustment seized need help
- help with car audio
- Stock radio dissasembly
- help ;-) I need to know bearing clearences for the big ends and mains plase
- Problem with ignition wires. PLEASE HELP!
- Want to replace seats.
- Engine Shaking?
- timing belt/water pump change in new jersey
- B16 dohc motor n tranny 4 sale..
- Trunk light sensor
- Spark plugs.
- Broken Fuel Door
- what can cause a metalic whining noise?
- D16y8 iac
- '03 Civic bearings
- Tps adjustment help
- k20a3 ecu stock reflash help & TPS adjustment help
- GSR head
- 01 EL SSRS heated interior into 05 Civic EX w/o SSRS
- DFI in d17
- Flashing D4 light and shifting not smooth
- catalytic converter crush washer not sealing
- A/C delete
- Help need radio code
- Power window problem
- Help with clutch
- Need help, 2006 civic brake light out
- Need help!!!
- HELP!!!Car Wont start every 30 minutes
- Radio Locked Need Help With Radio Code
- Noises under hood?
- door latch replacement part number help
- radiator cap
- Stabalizer bar.
- Sequential Gearbox for EG6 Civic is it possible???
- Alternative to Honda trans fluid
- 96 civic cooling system (radiator fan)
- Odometer reads 30,000 more when I left the mechanic
- spark plugs on 06 si
- 08 Civic Radio Button Cracked
- rear door outer handle & latch removal help needed
- rust removal/protection
- My GSR build
- Non vtec to vtec engine swap an 2 dash lights came on
- 1988 service manual
- Pinstripe Removal
- '98 Civic D16Y8 Sluggish Perf Problem
- Civic 4th Gen technical advice
- Integra throttle body on d16 manifold
- Clutch saving driving tips?
- 2001 civic lx rear drum to disk, i only need a yes or no
- Engine trouble!! Need help!
- changing license plate bulb
- Need to install a new interior driver's side door handle on 1995 Civic
- how do I put a Honda motor into a 76' vw camper van?
- Building a daily driven GSR for my EJ need help!
- windshield frosts over on inside
- what bigger injectors will fit in 1.7 vtec
- whats a larger altternator for an 01 civic
- 2008 LX Valve Clearance
- Humidity question.
- Coolant Temperature Gauge issue
- Brake bleeding problem.
- Garage May Have Trashed My Cylinder Head Need Opinions
- Transmission or Clutch problems????
- Power window issue
- Do i have LSD or open diff in transmission?
- I need help! metalic noise after fluid change
- Need help with Radio Code
- converter donut gasket
- Cat Delete Header and O2 sensor????
- Idle Air Control
- Just got a JDM D15B
- 92-95 JDM B16A ...all bolt on??
- I'm using rotella D in my b16
- swap have a few questions any help would be good.
- Power steering fluid.
- 97 ls integra.. gsr swap???
- recarpeting the roof
- D16 vs. B16 engines
- exhaust replacement
- Ctrl alt cat delete
- 2003 Civic LX ATF Change Question
- 02 sensor.
- 94 ex radio removal
- diy 95 civic ex coupe dashboard
- Fixed my car, thanks for the help
- Clutch
- dying coil packs
- '01 center panel keeps popping out
