Problem with ignition wires. PLEASE HELP!
Old Feb 25, 2010
martinezmily's Avatar
martinezmily is an unknown quantity at this point
the ignition wires or switch went bad on my 92 honda civic. i the switch out and it works but i need to play with the key a little bit in order to keep the car running. i want to know if i buy used ignition wires can still use the same key?? im not replacing the entire ignition switch, just the wiring part. it looks like this
http://lh6.ggpht.com/shotbaker1/SM2e...0/DSCF3457.JPG
i am asking this because i think the key has a chip. and if i replace the wires the key wont work. PLEASE HELP ME!
Old Feb 25, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: Problem with ignition wires. PLEASE HELP!
That is a 98 harness, 98 do not have a chip in the key, so that should not be an issue. Were you swapping that 98 harness into your car?
mrohitredd
May 28, 2015 10:03 AM
pincookie1
May 4, 2015 12:22 PM
Fastfebur
Apr 22, 2015 01:37 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Doc
Dec 12, 2001 11:47 AM
