Gas cap.
Old Apr 2, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Gas cap.
Why does my cap making a sucking sound sometimes, and sometimes there is no sucking sound? Isn't it always supposed to retain pressure? My fuel pressure test came out good, but I'm wondering if my cap is leaking sometimes.
Old Apr 2, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Gas cap.
I notice mine makes the sucking sound more when I'm low on gas. If I have half a tank and I'm filling up it does not make that sound. I also find that the longer the gas sits in there (If I use less over a longer period of time) it causes more suction. I know this does not really answer your question, I just figure I'd tell you how mine seems to work.
Old Apr 2, 2010
Re: Gas cap.
well I agree with that but this time when I was low on gas there was zero sucking sound, which is weird and not the first time it's happened.
Old Apr 2, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Gas cap.
Maybe when you put the gas cap on, you didn't do it as tight as usual? I'm throwing stones here
Old Apr 2, 2010
lowlife9's Avatar
Re: Gas cap.
doesn't that throw a code if its not air tight i remember people failing emissions test for faulty gas caps.
Old Apr 3, 2010
hindude's Avatar
hindude will become famous soon enough
Re: Gas cap.
mine works the same as tbohar. i get a bigger sucking sound the lower i am on gas. it seems like this would be the norm. I always go 4 clicks tight after i fill up too. maybe that will make a difference.
Old Apr 3, 2010
Re: Gas cap.
it depends on the evap purge cycle. every so often, the built up vapors get released into the engine to burn up. when you stop the car, sometimes you will have trapped vapors and other times you will not. its just luck i guess.
Old Apr 3, 2010
Re: Gas cap.
There is a spring mechanism in the gas cap, what odes it do?
Old Apr 4, 2010
Re: Gas cap.
To answer my own question, it must have to do with pressure in the tank when it's slushing around.
Old Apr 4, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Gas cap.
Sweet, now you can rep yourself
Old Apr 4, 2010
lowlife9's Avatar
Re: Gas cap.
if i remember correctly i haven't had that suction sound in a very long time full or low tank what problems would that cause if there was a problem ???
Old Apr 4, 2010
Re: Gas cap.
if there is a problem with the evap system (like a leak), the check engine light would come on right away. it could just be your car is working well burning all the vapors.
Old Apr 4, 2010
lowlife9's Avatar
Re: Gas cap.
ok yeah no check engine light so guess im good but i probably should change that filter it has never been changed going to look at your DIY.
Old Apr 4, 2010
Re: Gas cap.
What filter, evap? What will it cause if it's clogged?
Old Apr 5, 2010
Re: Gas cap.
evap filter usually doesnt need changing for 100k miles. it doesnt get as much use as a normal engine air filter. but if it gets clogged to the point where not enough air is drawn in, it may mess with the evap system purge cycle.
Old Apr 5, 2010
Re: Gas cap.
It's amazing how much stuff isn't even mentioned like changing the fuel filter. Any way thanks for the info as usual gearbox.
mistahlorax13
21
Nov 18, 2015 12:47 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
Juanb24
Sep 15, 2015 12:39 AM
NaturalSelectio
Sep 6, 2015 06:59 PM
dantheman42
Sep 4, 2015 01:10 PM
