clean brand new headlight bulbs?
Old Mar 11, 2010
laack's Avatar
laack is an unknown quantity at this point
2 schools of thought on this one..
anything, including alcohol wipe, touching it will leave a small amount of residue that can cause breakage of bulb.
clean any dirt from sitting/prepackaged contaminates to prolong life of the bulb
where do you stand? I finally got my new bulbs in the mail and i just want to try and get a consensus on your new in box bulb installation.
Old Mar 11, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: clean brand new headlight bulbs?
Typically I use rubber gloves. If you need to use alcohol Im sure it will not hurt and it evaporates.
Old Mar 11, 2010
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
I clean, some residue will always be there....when it's oil it will make it worse....
Old Mar 11, 2010
BlueEM2's Avatar
Whachya lookin at?
I just throw them in. Never had a problem.
Old Mar 11, 2010
at the factory, its mostly machines doing the work so you are pretty safe to pop them in. but using a hi purity alcohol should not leave streaks and if it does, try to wipe the bulb immediately with a dry cloth so it doesnt dry on the bulb. holding the bulb to a bright light is an easy way to see if deposits are being left on the glass.
bsmiley
Apr 27, 2015 01:27 PM
2k1civicman
Dec 19, 2001 05:27 PM
SWEETRIDE
Nov 27, 2001 05:52 PM
aZnVoYCe
Nov 15, 2001 04:48 PM
