I need help! metalic noise after fluid change
Old Jan 26, 2010
laack's Avatar
laack is an unknown quantity at this point
97 civic... 109xxx
i just drained refiled man trans, oil change with castrol 5 w 30, mobile 1 filter, new airfilter (fram) and new plugs (ngk platinum) and checked pcv valve..
triple checked all fluids before and after starting engine for the first time. after startup its wining almost like a metal on metal with no lubercation. i didnt drive it, just shut it off. rechecked oil filter, removed it. oil poured out so i'm led to believe oil is circulating. reinstalled let it sit for a few minutes checked oil agian added about a cup and started again.. same noise after about 30 seconds of running
i'm to paranoid to drive it to a shop right now, a tow truck will be my option if i start it again later and the noise continues.
what are possible causes for it to start making noise after routine mx that? noise was NOT there before.
no check engine light
no ticking/knocking
please ask for more details if you need them.
idle at 1500 rpm
i didnt do an ecu reset yet
it only ran for 30 seconds
double post from general forum.. i figure this is more appropriate here. can someone delete other one
Old Jan 26, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: I need help! metalic noise after fluid change
Originally Posted by laack
97 civic... 109xxx
no ticking/knocking
idle at 1500 rpm
Did you make sure you put back all the caps and dipsticks?
Old Jan 26, 2010
laack's Avatar
it ended up being power steering pump bearing.. I didnt have any lights so i drove down the road to a shop. quick diagnosis and easy repair
just plain bad luck on timing
Old Jan 26, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Hey ummm, my PS bearing is making noise. You say it's an easy fix? I've also got a bad bearing on the PS pulley, but I don't want to pay 40 bucks for a new pulley assembly.
Old Jan 26, 2010
laack's Avatar
junkyard pump-$25 after some crafty negotiating, $14 in new fluid
Old Jan 27, 2010
I don't like my junk yard, it's not fun haggling with the owner. What kind of nonsense is it when the guy gets offended when you haggle? What, should I be expected to walk in there bent over with my pants down, accepting face-value? I bet he wouldn't get offended then.
Old Jan 27, 2010
D&D? lol they got mad when i said their price was too expensive and left. they wanted $20 for an ignition coil and i can get them all over everywhere else for $10. they usually have no parts anyways, just some junk like broken gauges and oil caps.
Old Jan 28, 2010
No, airport auto wrecking. The prices at D&D and airport both suck. And pick n pull's latest civic is a 95, probably stripped to the frame.
edspyhill09
Jun 12, 2016 02:45 PM
RIPSAW
Nov 6, 2015 04:36 AM
mrohitredd
May 28, 2015 10:03 AM
markp94
Apr 30, 2015 09:19 PM
CapYoda
Jan 7, 2002 03:20 PM
