Engine Shaking?
Old Feb 24, 2010
JDMbosslady's Avatar
JDMbosslady is an unknown quantity at this point
Question Engine Shaking?
I'm not sure whats qoinq on with my civic, Everytime i start the car it starts shakinq like crazy!!! Like with my Accord it would shake and then stop once you put the car in drive and you drive it. HOWEVER, the civic doesnt stop shakinq even after putting it in drive.
Could be that its missing the engine mounts? that was my number one guess.
i'm not too sure because i've gotten so many different answers.
Opinions Please (:
JDMbosslady
Old Feb 24, 2010
Anticrime's Avatar
Anticrime is an unknown quantity at this point
Re: Engine Shaking?
what year and whats the mileage?
you probably just need a tune up.
Old Feb 24, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: Engine Shaking?
missing engine mounts...lol. its just loping :-D. seriously tho, it could be the harmonic damper...maybe
Old Feb 24, 2010
Re: Engine Shaking?
Its a 1995 with 160,000 miles.
Old Feb 24, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: Engine Shaking?
Anticrime is right. If it's not a mechanical thing like loose engine mounts then it's a tune-up issue, probably caused by weak spark. Do a major tuneup if you need to.
Old Feb 24, 2010
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Re: Engine Shaking?
check your crank pulley bolt if it is loose the whole car will shake violently
Old Feb 24, 2010
Anticrime's Avatar
Re: Engine Shaking?
if its the whole car that shakes, then its not a mount issue. if its just the engine that shakes then its probably a loose mount.
Getting a tune up will help your car last, run smoother, and save gas
Old Feb 24, 2010
Re: Engine Shaking?
Thanks guys (:
Old Feb 24, 2010
Re: Engine Shaking?
Distributor cap/Rotor, wires, plugs, fuel filter, air filter.
If you have more money:
02 sensor, MAP sensor.
After a tuneup, run carb cleaner through the intake several times, drive it a bit, then check idle RPM.
Old Feb 25, 2010
Re: Engine Shaking?
Ahh, im qettinq the tune up next week I'll make sure to do that. Thanks.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
blaketippett
May 29, 2015 08:02 AM
RickyRocket
Nov 30, 2001 10:14 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
colombianDXcivic
Nov 8, 2001 05:26 PM
