vetc oil pressure Problem
Old Apr 19, 2010
memo_ksa's Avatar
memo_ksa is an unknown quantity at this point
Angry vetc oil pressure Problem
have vtec pressure switch wire BLK/BLU wired straight up to ECU B9 and grounded at the engine bay. because i could not find the plug that comes from the ECU. so made a custom wire.
but i still have the code for the pressure switch, it reads battery voltage at the ECU B9 terminal if it's useful to you.
what does this mean? how can i fix it? can i jump with the solenoid?
k24a1 engine 02-04 k20a2 wired
thanks
Old Apr 19, 2010
memo_ksa's Avatar
Re: vetc oil pressure Problem
I think my problem is her
I don't havet
Old Apr 20, 2010
memo_ksa's Avatar
bump........
Old Apr 21, 2010
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
have you tried k20a.org?
Old Apr 21, 2010
memo_ksa's Avatar
yes. but No one can help me ther
Old Apr 21, 2010
memo_ksa's Avatar
http://www.k20a.org/forum/showthread.php?t=74810
Old Apr 21, 2010
You VTEC...I-VTEC
well your best bet would be on there. are you using a k20a2 vtec solenoid?
Old Apr 24, 2010
memo_ksa's Avatar
No , I use k24a1 vetc solenoid
Tomorrow I bay solenoid for K24A2 like this pitcher
K24A2
and that for K20a2 its same
Thinx man
I well told you if i fixed
Old Apr 24, 2010
You VTEC...I-VTEC
there is always the option of turning that sensor off in kpro. I am using the k20a solenoid and it doesnt have that sensor.
Old Apr 26, 2010
memo_ksa's Avatar
What is my option I have ? can you told me , can i jump with the solenoid
i have vtec pressure switch wire BLK/BLU wired straight up to ECU B9 and grounded at the engine bay. because i could not find the plug that comes from the ECU. so made a custom wire.
Theta for K20a2
http://www.wheelsjamaicahost.com/whe...topic=117256.0
I kept of in ecu but I need a perfect swap
thanks
Xuhme
21
Aug 7, 2023 03:40 PM
Supramk3
May 11, 2015 07:55 PM
usajags84
May 10, 2015 08:11 AM
Chronic_issues
May 8, 2015 05:40 PM
2k1USMCivic
Jan 1, 2002 01:24 PM
