Sticky throttle cable.
Old Mar 11, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Is it possible to clean the cable? I need to add oil to the existing grease because it's not free flowing like it should be. It's causing my rpm to shoot up to 1500 due to not retracting properly.
Old Mar 11, 2010
FGsmasher's Avatar
FGsmasher has a spectacular aura aboutFGsmasher has a spectacular aura aboutFGsmasher has a spectacular aura about
Re: Sticky throttle cable.
IMO, I doubt it is the throttle cable it self with the problem.
You say your engine is surging? At idle? Only when the motor is cold?
Can you feel the gas pedal "sticking" when you hit the gas? Have you tried adjusting the throttle cable to remove any slack, or allow for more slack if it is too tight?
Old Mar 11, 2010
lowlife9's Avatar
spray some lithium grease on the cable and push the throttle in and out.
Old Mar 11, 2010
Thanks but I already know 100% it's the throttle cable. Everything else is clean and adjusted. I don't have idle problems, except when the cable is sticking.
Old Mar 11, 2010
Will try thanks.
Old Mar 11, 2010
lowlife9's Avatar
check this out
http://www.keysolutions.com/M-Class....ent&AutoFramed
Old Mar 11, 2010
See, now I feel like a dumb ***. I swear I have adjusted the cable screw more times than I can remember, and I always have to readjust later due to no slack. So I don't know wth is up with that. Maybe, like you said, the screw needs to be adjusted during cold weather since everything contracts.
And the throttle cable is a no-bind system. It was completely free.
Old Mar 11, 2010
laack's Avatar
laack is an unknown quantity at this point
I didnt read through all the responses, but does this mean that lubricating the cable didn't fix your sticky gas pedal? my 94 dx has/had the same issue that popped up over night. i was about to replace the trottle cable, but after removing cable i moved it around and it moved freely, i decided to check butterfly valve first. throttle body was free and clear, but the spring on the throttle (the thing that cable connects to, i dont know name) was bound with gunk. degreaser, toothbrush and sprayed it down in sylicone. back to 100%
likely not your answer, but easy place to look with out doing any legitimate work.
Old Mar 11, 2010
I just call it the throttle cable pulley. Assuming the throttle cable slack is within spec, the throttle cable pulley should be checked. Make sure the pulley bolt is on properly.
But yeah, my cables moves freely too, no binding/sticking.
Old Mar 11, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
http://www.toyotasimulator.com/
Just kidding. Toyota's don't have throttle cables.
Old Mar 11, 2010
lowlife9's Avatar
lol lately my local news has been reporting every single accident involving a toyota its getting ridiculous.
Old Mar 11, 2010
Awjvail's Avatar
Not just your local news.
True story: Today on the highway, I was surrounded by Toyotas. A recalled Camry behind me, a recalled Prius beside me and a recalled Corolla in front of me. I swear my life flashed before my eyes.
Anyways.. not to thread jack.. moving along....
Old Mar 11, 2010
don't worry about the Corolla in front, but the Camry behind - it was stuck throttle problem!
Move ahead, am sorry, couldn't help but say that!
Back to OP - I assume you checked the pedal assembly itself, right?
Old Mar 11, 2010
All part of the plan to pull the plug on the economy. The whole thing is theatre, not an accident. Accidentilly on purpose, more like. Just like GM focusing on SUV's for years and years, and Mazda/Toyota/Honda/Subaru all releasing completely shitty external car designs for 2010. "Ummm yeah, we thought making our cars look worse than the previous year would boost sales." come on, these car companies aren't stupid. They know exactly what the population wants, always.
2008 Mazda 3
2009 Mazda 3 (Is this part of their new sea creature themed lineup?)
Old Mar 11, 2010
The problem seems "fixed" for the time being, but I will check the peddle.
Old Mar 11, 2010
Awjvail's Avatar
People just don't/can't see the big picture.
2008 Mazda 3
2009 Mazda 3 (Is this part of their new sea creature theamed lineup?)
Old Mar 20, 2010
Actually, it is a sticky throttle cable. When you remove the cable from the throttle pully, it feels like it's not binding. But when you put it back, it's dragging against the plastic housing due to excess friction. I'm going to run some motor oil down it. Should work good.
Old Mar 23, 2010
Yeah the motor oil didn't really work all that well because the real problem with old cables is that the grease at the pinch point has dispersed. So you have to remove the cable where it's pressed into the brackets to relieve friction. This solves the problem, but you will need to re-adjust your cable slack.
Old Mar 23, 2010
time for new cable? would be less expenses than having the cable stick when it should not... See ToYoT...
Tyler93
Mar 20, 2016 09:03 PM
Bruce2
Sep 27, 2015 08:45 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
NROD315
Sep 23, 2015 03:46 PM
Bricoleur
Sep 9, 2015 12:30 PM
