powerbuilt harmonic damper tool
Old Mar 29, 2010
laack's Avatar
laack is an unknown quantity at this point
dumb question- I'm in the process of ordering all the parts for a timing belt job. looking a the crankbolt tool, how do i connect a breaker bar to it to wedge against the ground. it just doesn't seem like the square insert would stay attached very well when i start to torque the crank bolt.
I know several have used it here, any issues with it slipping off when torque applied? tool advertises compatible with 92& newer 1.6l. mine is 1.5. will it matter
94 civic dx 1.5l
is the pulley 50 mm? is this the correct tool?
http://www.amazon.com/Powerbuilt-648...9893581&sr=8-1
Old Mar 30, 2010
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Re: powerbuilt harmonic damper tool
once there is pressure on everything they tend to hold in place and not slip out
and your tool should fit
Old Mar 30, 2010
laack's Avatar
perfect. thanks
Old Mar 30, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
The breaker bar won't slip out, I did this job about a year ago with the same tool. It will help if you support the other breaker bar (the one on the actual cam shaft bolt) with a jackstand. There is a video of the process on youtube.
Old Mar 30, 2010
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
http://www.youtube.com/watch?v=RE-pzP8g_x4
https://www.civicforums.com/forums/3...t-diy-2-a.html
pilebuck13
Sep 21, 2015 10:45 PM
OptimisticWay
Sep 18, 2015 09:37 PM
AffliictiioN
Sep 16, 2015 02:21 PM
