Need help with replacing MCU/Fuse box wiring diagrams would be usefull
Old Mar 6, 2010
danielw's Avatar
danielw is an unknown quantity at this point
ok so I'm trying to do this for my mom while i'm out of work and have nothing better to do. She's got an 05 civic ex that has been having crazy electrical problems (wipers wont stop till you tunr the car off, window wont go down, headlights intermitently don't work when wipers are on etc.). Anyway, I'm pretty certain from my reading that its an issue with the MCU which is in the fusebox. So I want to just replace the entire fusebox. I was hoping someone could hlep me by providing a diagram and/or instructions on how to get to this and replace it? I think I'm gonna give an ebay fusebox a try at least once and if that doesn't work just buy it through the dealer. Any help would be greatly appreciated.
This is the part I'm looking at (I think its what I need):
http://cgi.ebay.com/ebaymotors/2001-...item3ca3f2a71e
Thanks,
Daniel
Old Mar 7, 2010
danielw's Avatar
Re: Need help with replacing MCU/Fuse box wiring diagrams would be usefull
bump
Old Mar 7, 2010
CraigW's Avatar
I don't have the PDF printer on this computer... For the most part you take the - lead of battery loose then the + & wait 3 minutes, remove the front connectors on the box. Then remove the screw so the fuse box will drop down, then remove the back connectors & remove box.
Install in reverse order and perform idle learn.
As far as the part # I would do some cross reference before purchase to make sure it will be the same part.
Old Mar 7, 2010
danielw's Avatar
great info craig! I've been reading some of your other posts as well. So what will I need to do to actually access the fuse box? Does the whole dash need to come of or is it just a couple of clips under the stearing wheel? I've read both...
-Daniel
Old Mar 7, 2010
CraigW's Avatar
There is a panel under the wheel, 2 ***** twist to release.
You will see the under hood fuse box, the bolt at the bottom allows it to drop down lower for access.
Many connectors present.
Old Mar 8, 2010
danielw's Avatar
Thanks dude!!!
ORskier
May 7, 2015 04:54 PM
darwin-t
Apr 18, 2015 09:29 PM
thesushiboy
Apr 12, 2015 02:54 AM
Jimmy24
Nov 27, 2001 05:44 AM
GabberHead
Nov 20, 2001 07:32 PM
