Alternative to Honda trans fluid
Rep Power: 787 Re: Alternative to Honda trans fluid
the honda stuff is the best for auto trans. the only other almost safe substitute is amsoil atf but its way more expensive and i only know a few people that tried it. who knows what it would do over time. i also add some LC20 from lubecontrol.com to make the fluid last longer. hasnt caused any additional problems for 40k miles after the trans started slipping before using the additive.
if you have manual, its not as picky.
Rep Power: 242 Re: Alternative to Honda trans fluid
If you have a manual, use honda mtf. 2 quarts is 15 dollars, and will last 15k miles. Don't use 10w-30 because it's thicker and you won't get as good gas mileage. It also doesn't have additives. You save money by using the honda stuff.
1 Post
Rep Power: 328 Re: Alternative to Honda trans fluid
if u have a manual, u can you "GM syncromesh friction modified"
it is better than honda's if u have a slipping transmission and allows u to obtain smoother shifts. research bout it n you'll see wt i mean. (manuals only)
i assumed hondas stuff would be more expensive thats why i asked. i guess i need hondas then. i supose i have to get it from honda dealer?
Rep Power: 0 Re: Alternative to Honda trans fluid
We use this at my works for honda trans and many other import atfs it is actually made better then any of them so that they meet the standards and exceed them, and the only manufacturer who has had a problem with it was hyundai, not kia or mitsubishs odly (All use SP3 ATF)
http://www.mobiloil.com/USA-English/...hicle_ATF.aspx
Rep Power: 0 Thread
Xuhme
21
08-07-2023 03:40 PM
jessicakaybby
04-20-2015 12:11 PM
Bartkat
20
02-19-2002 01:29 PM
