Non vtec to vtec engine swap an 2 dash lights came on
Rep Power: 0 Non vtec to vtec engine swap an 2 dash lights came on
I went from a 1.7 non vtec to 1.7 vtec engine swap and installed a kpro ems and my imobaliZer light and srs air bag light came on and I have no idea how to fix it. The ems won't let me tuen them off would anyone know how to fix it?maybe since I changed the engine harness dose that mean I have to get a new key since it has that chip to match the new harness ?
1 Post
Rep Power: 364 Re: Non vtec to vtec engine swap an 2 dash lights came on
If you changed the ECU, then your keys need to be reflashed, and this would cause the immobilizer light. You can turn it off in kpro. Parameters>Misc>ECU Options> "Immobilizer enabled".
As far as the SRS light, try to reset it (search the forum on how to reset it- there is a good video on youtube that shows you how). If it comes back on, you have an issue. Did you disconnect any yellow SRS connectors when you installed kpro (or had it installed)?
voblak2
20
05-04-2023 02:08 PM
cloudguy
04-28-2015 05:02 AM
twtron
04-17-2015 12:09 AM
