- 93 honda civic dx no power to fuel pump
- Car Start Issue When Warm
- Electrical/battery/fusebox help
- 1981 Civic 1.5 liter Dies at Stop Lights.
- 1992 Civic 5th gear issue
- d16 turbo, New injectors flood engine on crome
- Engine wont start
- No idle and doesn’t rev past 2000 rpms
- 1982 Honda Civic DL 1500 rear suspension bushings
- Engine Knock
- Should I flush my transmission?
- Rust repair
- K20–>K24a3 complete swap ??? HELP
- Are these shocks worth the price?
- D16Z6 Intermittent Idle/Power Problems
- 1979 1.2 Hondamatic Engine and Transmission
- Fuel line leak
- Help me with my eg civic brakes!!!!!!
- Sun visor repair ideas?
- 1992 VX Hatchback Tach issue
- 1990 Honda Civic LX dying while idling.
- Fuel pump issue
- Clutch safety switch?
- 1995 LX Bad ECU?
- Cold delayed start
- 1995 DX Sedan B18b1 swap t
- High Pitch Noise Only While In Gear
- Heat
- 1995 civic ex coupe - rotten metal issue
- 1995 Civic Del Sol fuel tank issue. Rock and a hard place.
- missing coolant
- 1994 EG hatch help please?
- 92 Civic blowing billows of black smoke
- 2nd gen rear window hatch.
- Wet rear and front passenger floor 95' Civic
- 95 civic coupe si brakes pads
- 1981 Wagon resto help!!
- Starter In, Aggravation Gone.
- Motor problems
- Constant hot air blowing
- Engine continue to run with brake pedal applied. No joy with ignition switch
- Dome light works pass door
- To Evap or Not?
- 91 d15b2 problem
- 94 Civic Cluster Fail
- '93 5 speed fit into a '91 LX ?
- 1995 civic runs rough intermittently
- Help! Coolant bypass connector(?) Leaking!
- Low idle 95 stock civic
- 1990 Honda LX has very strange front drive
- limp mode
- Honda Civic 1992 not turning over
- Headgasket?
- '91 LX Sedan Auto Transmission ?
- Blowing Fuses
- 1986 Civic DX Questions...
- Weird loss of power, once car is driven turned off and back on
- 1996 Honda Civic ex won’t start fuel injectors not firing
- Tps replaced high idle
- D16Z6 engine knock
- 1995 Civic LX Automatic
- 1981 Civic won’t start when hot
- Help, Can't Start - 95 Honda Civic DX Coupe -
- New to forum...2 questions regarding 94 LX
- D16y8 ob2 to d16z6 ob1
- Sunroof Repair
- Weird weekend: ‘91 Civic HB with pool of gas on ground
- Z16z6 timing belt and head gasket finished!
- I need some help with my heater
- I need some advice on 1994 Coupe DX ECU
- 1995 Civic EX trunk leak
- timing belt broke shortly after this video....
- Starting Issue after timebelt/waterpump.
- Clutch Cable Alignment
- ‘90 Civic doesn’t like water
- Please helppp fresh rebuilt d15b7 idles at 2500rpm
- Black Residue D16Z6 Might Swap to B Series (noob)
- Manual Shifter out of alignment
- 1995 Civic Ex, engine won't turn over
- Car stop running unexpectedly!!!
- Speedo Shakes
- Exhaust Leak Considering Welding
- 1985 Honda Civic Gasoline Smell
- CEL Code 8 TDC Sensor Position
- Looks Like The Blunt-Mobile Blew It's Head Gasket
- 1999 Civic exhaust trumpet noise
- Pick-up coil problems
- honda civic 2001 1.7 16v automatic, rpm injection system problem.
- 91 Civic engine swap shops in CA?
- ECU limp mode
- Map Sensor Code 5
- High idel on a 93 1.3 civic
- Spark plug sleeve
- 98 Honda Civic in limp mode won't pass 3500 rpm
- 95 Civic no start but cranks
- Low Idle
- No start.
- fixed my a/c problem.
- not many threads on 1980 hondas
- air cleaner was missing parts
- Leaking coolant behind engine
- 4th gen 91 civic si washer reservoir r and r
- Did I blow my transmission? Any ideas?
- Battery Charging
- Windshield Spray Nozzle Cleaning
- Water pump pully.
- Coolant and Oil Problems -- HELP REQUESTED (THAT'S WHY I'M HERE)
- 1990 Honda Civic Jerking
- 1989 crx dx automatic stutters at 4500 RPM
- Ebrake is applying itself
- 87 Honda Civic si stalling and no power need help!
- Upcoming CV Axle Change
- won't shift into 4th gear
- 1993 Civic swap, idle surge/loop
- Help!!! 91 DX D15b2 Swap to --> D16a6 Head with D15b7 Block
- 91 Dx Civic, died out with loss of power on freeway. No start
- clutch pedal mount is cracking on my 1990 civc
- D16Z6 in ek hatch wiring?? NEED HELP!
- Injector problem
- Car won't start by turning the key.
- 89 Civic Dx No Start!
- led dome light won't turn off
- Smoke coming from valve cover
- Engine Coolant Sending unit plug
- 91 civic 1.3L engine rebuild kit, whats required?
- radiator problem
- Pulley/balancer
- Auto trans
- vibration......
- Window getting loose, repair procedure?
- 1980 honda civic wagon wiper motor
- 89 wago trans oil leaking from passenger side
- Idle surges when engine is warm, low engine temp or IAC or FITV
- 89 civic stals when going to an idle
- 91 Civic trailing arm & drums
- 1991 4gen with a lot of problems
- 93 Civic stalls at Idle
- 91 hatch No fuel pressure
- My 91 civic w/a b20 swap has power loss and a stiff upper coolant hose
- 1989 Civic motor change after problem
- surging idle on snap acceleration.
- 93 hb vx high idle
- 95 Civic not start
- Steering part for 1991 civic
- 1995 Civic LX Overheating
- 1994 Civic VX - O2 sensor code (1)
- Another Carburetor Thread
- Heater Valve Leaking
- 1987 Civic sedan idle issues
- 1995 Civic Ex Idling Issues
- d15b2, skipp and no power
- 1994 civic ex surging & hard starting????
- Clutch pedal slow to return
- Help car won't pass 4rpm
- Leaking Clutch Fluid
- noise from front left wheel area, in town only
- New Valve Seals, Guides, Lap, or 3-point?
- trouble code - 15 odb1
- JDM h22a no vtec
- My 1995 civic EX 1.6 sedan accelerates very slow
- what distributor is this?
- 1986 civic transmission
- Bought a 94 civic that is h22a swapped
- 1993 Civic Battery Problems
- Del Sol Door Latch Rotted out?
- Newer Seats in Older Honda
- 1994 civic 1.6 vtec help please
- Crank no start, 94 civic dx
- I have a problem
- Quick question
- A/C install
- Banging noise from front suspension in turns
- Squeeling/grinding noise from passenger rear tire
- Coolant leak and fluctuating temp gauge
- Oil Pressure Light On
- 8th gen to 9th gen
- De-powering Steering Rack
- 95 civic ex coupe manual drivetrain problems
- HELP save my '95 civic vtek!
- Hondash Bluetooth Live Data Tool
- 96 hatch. P0420 code, new cat still bad.... d16y7, PLEASE HELP!
- 85 Civic Wagon - Idle and Power Issue
- Electronic Air Control Valve.
- Cant find parts for my wagovan
- Dead ecu or ?
- '95 Del Sol Timing Belt
- 1996 Civic EX Grinding Noise
- Hot, Humid Outside TB Surging Again
- Engine Hose Help!
- 1993 Honda civic EX D15 wont start. A lot replaced
- 95 ex blown head gasket?
- Help to make my '94 fire up?
- Bolt Size For Proportional Control Valve and TB ?'s
- Is this EJ2 still worth ANYTHING?
- No Crank Issue
- 1989 Civic Intermittent Starting Issues.
- Engine Stalls When Starting On Incline or Decline
- Unknown Hose. Need help
- D15B7 Warped Head Replacement
- HVAC Issue Continued
- D16z6 oil smells like gas, am I running rich?
- front wiper motor
- 1990 civic wont start main relay makes clicking noise
- Interchangeable parts for 1995 honda civic ex coupe
- 84 civic fuel delivery problem
- overfilled my engine oil
- Oil Leak
- Wife is away and just crashed her Civic into a post, HELP!
- Need Help - New Honda Owner
- upper solenoid gasket
- bucking problem
- Another Possible Headgasket Breach Post
- 1995 15 ACG fuse Blows
- rear main seal
- How Can I Repair Rust Around The Wheels
- Cranking but not starting
- HELP:93 Civic code 9 and engine sputtering
- Fuel gauge won't work Help!!!! Please!!!!
- Starter won't turn
- 1990 Civic Won't Start
- 1991 civic wipers
- lockout selonoid
- 1995 Civic no start PLEASE HELP ME!!!!
- 1994 civic starts then dies immediately.
- 93 Civic running rough-dying
- Coolant in my oil, intermittent heavy smoking
- oil in cylinders
- 84 Honda Civic puffing smoke out of carb
- Stolen ECU?
- 95 Civic code 70
- idle surge contiues... help!!
- moonroof motor not functioning
- 94 won't start, head gasket leaking
- Loud motorboat type sound and drives rough
- New to me 94 with issues
- Engine code question
- vtec
- stuck valves
- head swap
- Limp Mode/Wont Start?
- 1992 civic vx w/ b18b1 stalls while driving need help
- temparture issue with my 91 four door sedan
- 1994 SI 1.6L persistent idle surge
- New Head Gasket - Oil leaking bad
- Rough acceleration 1500-3500 RPM
- Honda Civic 1991 LX driver door hinge replacement
- 95 civic ex recirculation
- 1995 vtec-e cranks no start when warm
- Clutch Issue
- 1995 Civic Hatchback VX Vtec-E Knocking at Low RPM
