Log In
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 [3] 4 5 6 7 8
  1. Vtec oil pressure switch (Delete)
  2. A/C Killing Engine
  3. O-ring
  4. miss cyl 2 & 4,,
  5. Crank wont start
  6. Engine diagnostic Plug?
  7. seafoam?
  8. 91 LX sedan
  9. Rough idle and shutdown
  10. Overheating issue
  11. 93 civic only starts with ether and will stay running
  12. stretch(tty) bolts on a Honda Civic 1.5
  13. 95 1.5 non vtec hard starting Civic
  14. Soft clutch pedal
  15. Distributor Igniter Failing
  16. Starting issues 90 DX
  17. 94 Si TO or IS Bearing Prob?
  18. Hard miss at speed???
  19. Ignition Output Signal
  20. 92 civic no spark
  21. 1.5 66kw dual injected wont start when the engine is warm
  22. Please Help Me!!! 93 Civic Starting Problems
  23. Idle problems
  24. cant pass emissions
  25. 83 Civic 1500 Timing Issue
  26. 1995 DX failed emissions with high CO
  27. 94 Civic VX 3 codes: 15, 22, 48
  28. Sticky Shift
  29. distributor help
  30. 2015 Civic Passenger Airbag Light
  31. 1995 Accord Fuel Issue?
  32. 94 civic po6chipped vtec starts at 5000 cuts of at 5500
  33. Car feels slower?
  34. Del Sol will not crank in humid/rainy weather..what gives?
  35. Exhaust Fumes Inside Cabin
  36. Intermittent brakes and effects rpm's?
  37. My Rear Window Defroster does not work
  38. The tanks half full !!
  39. 1991 Civic: starts, runs until it warms, then chokes & won't start
  40. Buyer pulled engine wires, car won't start?
  41. '93 1.6 Civic Hard To Start Aftrer Sitting For a Week
  42. Need a hand! '89 si hatch not starting
  43. heater not working
  44. 1995 Civic cranks great , won'tr start until ignition is on for a minute
  45. Weird moisture related idle issue
  46. Honda Civic b16
  47. 1994 turns over but wont run
  48. need inner tie rod number
  49. Vehicle shaking upon starting
  50. "Temporary" brake failure after lots of stop-and-go traffic
  51. Motor
  52. Does this pulley, belt noise sound familiar to anyone?
  53. what has she impaled?
  54. 1994 civic wont warm up
  55. Misfire at high rpms!
  56. Help! Tail lights not working, dash and front parking lights workin fine
  57. Jerky shifts?
  58. 1992 DX Hatchback lock will only open and close when door handle is pulled
  59. AC Compressor stopped working during freon charge
  60. B18C compression
  61. Where is VSS located in '95 civic dx? Also imminent tranny failure?
  62. Engine revs high and low after alternator replacement and throttle body cleaning . .
  63. 94 civic. Key won't start car. Have to jump starter every time. Help please
  64. 1981 Civic Carb/Fuel issue
  65. 1990 Civic SI Heater working off and on/No radio
  66. 95 Civic slow start in drive.
  67. Please Help! d16z6 crank but no start
  68. new member in need of help.
  69. Passenger Door Handle Broken
  70. A/C intermittent
  71. Misfiring issue on a JDM B18C
  72. Odometer registering 12 miles for every 1 mile
  73. 93 Civic d16 starting problem only when it rains
  74. please help!!!!!
  75. Engine question!
  76. How to Remove Rear Disc Brakes from a Junkyard & Not Get Your Tools Stolen
  77. 1992 Honda civic dx brake fluid leak
  78. EGR how to video
  79. 1992 Honda Civic Dx Brake problems
  80. starting trouble
  81. transmission failure
  82. Transmission Identification
  83. Bad idle in hot weather
  84. Changed Starter, Now won't start
  85. 90 Wagon Engine Electrical Harness
  86. 1989 Civic Hatch
  87. Dual Vacuum D14 dizzy vacuum hose connections
  88. 1995 EX electrical Problem
  89. Upper hose HOT; lower hose kinda cool. Stat OUT..
  90. Idle SURGE vs. Running SMOOTH why...
  91. First post! And.. issue. My 1995 Honda Civic..
  92. Dizzy Leak
  93. 1980 civic door lock
  94. Aftermarket air intake to fit D15B
  95. Reinstalling rebuilt D15B8 - need help id'ing brackets & stays
  96. What FITV units are compatible between models
  97. Questions About the d15b SOHC VTEC
  98. 91 D15 IAC Bypass?
  99. Code 43 Only on Downhill
  100. Idle keeps varying from 500-1000rpm everyonce in a while
  101. Vtec swapped for d15b7
  102. Question on Vacuum Gauge Readings
  103. Lean Condition/Engine Shuddering/Misfire
  104. Stuck Harmonic Balancer Nut
  105. Multiplex Switch for civic
  106. wheel lock
  107. Chain of Events, HELP , puzzle.
  108. 1991 1.5L; new distr., good spark, 40psi fuel, won't start
  109. Shop Manual 92-95: Where's CV joint / axle section?
  110. Hondaed
  111. 95 civic ex with d16y7 engine problems
  112. 1993 Civic 1.5l sohc 16v
  113. 91 honda civic tail lights delayed by 1-15 min..
  114. d15b2/7 difficult start, runs, stalls.(with video)
  115. Punctured timing belt cover??? Help
  116. idle issues and bogs out once warmed up
  117. Need help.. Ezone??
  118. Vtec engine into non-vtek car
  119. 95 honda civic lx help with part location
  120. 95 civic shift issues
  121. EW1 Head Gasket
  122. flooded plugs
  123. Thermo fan switch
  124. Engine Stalls out on acceleration 1990 si
  125. Feels like a dead cylinder under 3500 rpm....
  126. first car is a honda, need help with the name of a part!!! honda civic 1990
  127. Timing belt
  128. DRL relay
  129. 1995 civic dx has a rough idle, poor acceleration when hot
  130. the sound of a bad lifter? bad lifter seals?
  131. 90 Hatchback door dash light
  132. What's causing my code 16?
  133. HELP!!! 1993 civic lights dimmed/no power
  134. 95 Civic D16z6 car cranks, but won't start? HELP
  135. 91 Honda Automatic Transmission sticks when cold
  136. 91 dx won't stay running
  137. 1995 honda civic backfiring....
  138. 95 Civic DX "race"-tuned Automatic
  139. 95 dx civic with a d16y7 having running problems.
  140. 03 civic lx 5spd. misfire codes but perfect idle..
  141. 94 civic dx ECU swap(stick)
  142. how do i remove the governer
  143. 94 civic ex smog fail
  144. 1984 Dx Hatchback start problems
  145. 95 civic idle issue
  146. 91 civic blower motor replacement
  147. Won't shift out of 1st in D3 and D4 now matter how high it revs
  148. 92 Civic starting issues. Please Help!
  149. Idle/Check Engine
  150. 95 DX Hatch Won't Idle
  151. 1995 Civic auto trans ratcheting noise while coasting in 4th gear
  152. engine diagnosis
  153. What did I do?
  154. Lost power to all gears!
  155. How to make a P06 OBD1 ECU work on a ZC SOHC NON-VTEC 1.6liter
  156. Engine swap questions
  157. slow acceleration standard lx
  158. Annoying starting problem
  159. SOHC ZC NON-VTEC ENGINE ECU issues
  160. 91 honda civic engine cuts out when slowing down and somtimes when driving or accelor
  161. I can't figure out clicking noise
  162. Can't get a grip on this.
  163. Just quit and won't restart.
  164. so its a canadian ricer "A"
  165. AC idling issues
  166. Coolant Leak/Idle Surge
  167. First time A/C job. I need help
  168. Oil In Spark Plug Chamber
  169. interior buzzing
  170. ECU Code #4: 89 Honda Civic Wagon
  171. Save the eg 93!
  172. speedometer stopped working but rpm works
  173. 95 Civic LX: Bubbles on dipstick?
  174. After a Night of rain, my 93 Civic won't start??
  175. help!
  176. Problems
  177. PCV Location
  178. 94 Civic hatch door panel
  179. 94 Honda Ex engine ticking
  180. Civic, why you no fuel?
  181. Check engine light help!
  182. 89 Civic -- what are these gaskets that came with my rear main seal?
  183. 95 Civic LX Rotational Noise
  184. '85 Civic Won't Start! Elevation?
  185. Civic smoking bad
  186. Free Wagovan.... Yeah right....
  187. 90 civic dx 1.5 running rough
  188. 94 Civic ex vtec HELP
  189. double checking idle fix
  190. Vent tube near steering rack?
  191. Weird question
  192. 1993 Honda Civic EG Overheating
  193. need lil insight d16z head
  194. Help help help! carb problem.
  195. 94 Honda Civic EX
  196. 94 hatch idle problems
  197. rack ur brains on this 90 dx hb no fuel prob, plz help!!!
  198. AC high pressure relief valve question
  199. D15B7 leaking oil and knocking.
  200. head got me f $#@d up
  201. Intermittent Start failure
  202. Head gasket problem
  203. 93 honda ex losing all electrical in dash. Then car dies out
  204. 1995 EX MAP Sensor
  205. Hose leak
  206. no power going to my wheels
  207. 1993 DelSol Si failed emissions (epic NOX fail)
  208. 96 civic stalling out, help!
  209. unidentified part
  210. Side Molding After Removal?
  211. '95 DX Misfiring Issues
  212. 95 Civic EX Idle Issue
  213. '89 1.5L codes,codes,codes
  214. Warped Timing Belt Cover on 4th Gen?
  215. 93 Civic randomly dies
  216. No Start 95 Civic Ex
  217. '89 1.5L wagon rebuild head, engine won't fire
  218. 95 Civic EX with D16Y8 Swap
  219. Hunting Idle
  220. 92 lx no fuel no spark please help
  221. 92 lx, very low idle, slight jerk when decelerating to stop
  222. 1995 civic lx problems lately
  223. 94 DX Parts Advice?
  224. blower motor?
  225. Can't Fill Gas Tank
  226. Brake Lights
  227. HELP!!!! My eg bogs out and dies when i give it gas
  228. 1990 civic SI no start
  229. Always Sputtering with Low Power
  230. hunting idle
  231. 1991 civic hatch steering wheel will not unlock??? what the heck?
  232. NEW here and got a question!
  233. 91 civic si check engine light on
  234. temp gauge on 95 civic?
  235. 94 civic plug wire issues
  236. 94 civic dx won't start after putting gas in it
  237. Is it worth doing a head gasket on a stock 92 hatch engine
  238. 1994 d15b8 block
  239. Erratic Transmission Shifting
  240. help please
  241. Burning coolant problem
  242. speedo acting funny
  243. 95 Civic Timing Issue
  244. 95 honda civic wont start, steering wheel and brake pad locked.
  245. TB rotor on AT car question
  246. Need Help Finding Parts
  247. 1.6 smoking need help! Video.
  248. Aftermarket or Honda
  249. 95 ex with d16y7 idle probem
  250. 92 civic dash lights not working
