Intermittent brakes and effects rpm's?
Old Dec 15, 2015
Civic-guy83's Avatar
Civic-guy83 is an unknown quantity at this point
I have a weird issue with the braking system in my '95 civic ex. The brakes will sometimes almost go full stroke and not stop the car unless u pump them up. They aren't spongy and the master cylinder has been replaced. Yes, they have been bled off and no change in the hydraulic fluid level. To make matters worse, yesterday when i stopped by the garage, I was pumping the brakes and the rpm's went up until i stopped, then came back dn. What's up with that? Any ideas or has anyone run into this problem before?
Old Dec 15, 2015
Re: Intermittent brakes and effects rpm's?
Nothing wrong. This is normal and expected so don't freak out about this part.
Can't say anything about the rest of your story though.
Old Dec 15, 2015
What causes the increase in rpms while pumping the breaks?
Old Dec 15, 2015
The booster operates using manifold vacuum.
You repeatedly pumping the brake pedal causes the same effect as a vacuum leak....until you quit pumping it.
Old Dec 15, 2015
Gotcha, thank you. What do think about there being a provlem with the master cylinder. Nothing else makes sense?
Old Dec 15, 2015
8/9th gen are the 2006-2015 cars. Also, you have a question, not a helpful DIY article. moved to right generation/out of the DIY section.
Old Dec 15, 2015
If you stand on the brake pedal without pumping, is there any braking action at all?
Assuming this is true....
Take it to loose gravel and do this, stab the pedal once and make the car skid using the 2 wheels that still have working brakes. Get out and see which wheels made skid marks.
The 2 wheels that did not make skid marks are the ones that have the problem.
If you can get this far, you've narrowed the problem area by half.
What does your mechanic say about this?
Old Dec 15, 2015
On vacation right now. Been really trying to replicate this. Just took it out again. It's just the front tires, disc on front and drums on back, no abs. So, if u crank it hard left, the driver side locks up and passenger is fine. Turn hard right and passenger locks up and driver is fine. This is when the pedal almost goes full stroke to the ground. Mind boggling!
Old Dec 15, 2015
So the front brakes work.....rears must be the problem?
Have you removed the brake drums to inspect?
Old Dec 16, 2015
mac25's Avatar
Dr Krieger of Modification
no abs means that the braking system is down to
master cylinder (if it was bad you would have brakes but they wouldn't be power assisted, so that should be fine)
proportioning valve: (could be leaking, but probably wouldn't cause intermittent issue)
brake lines (you would probably have no pressure very soon if one of these were blown)
front:
rotors (would not effect brake pedal travel)
pads (would not cause intermittent brake pedal travel)
calipers ***if leaking could cause issue, possible loose bleeder bolts***
rear:
drum pistons ***could cause intermittent pressure loss if seals are blown***
drum brake pads
drum cover (would not cause issue)
Pull off your front tires and look for leaks
then If you find nothing pull for the rear drum covers and look for leaks
(my guess rear drum pads are so worn that the rear pistons have slipped past their gaskets and are causing intermittent pressure lose while braking hard/ rear pistons are done and should be replaced if rear pad depth is thick)
Old Dec 16, 2015
front:
rear:
drum brake pads
This is very confusing. There are no leaks. Only the front tire to the side I turn to locks up, while the other side spins. Why Only on sharp turns does this happen, going straight is fine?
Old Dec 16, 2015
Weight of the car lifts off the inside tire making it easier to lock up.
Outside tire receives that weight, which increases traction and keeps it turning.
You were supposed to try that skid in gravel going in a straight line.
What about the rears?
Old Dec 16, 2015
Straight line, they act normal and so does the brake pedal. Only when turning sharp does this occur, with the wheel locking up and brake pedal going full stroke. Rears seem to be just fine.
Old Dec 16, 2015
Extreme wheel bearing play?
Old Dec 16, 2015
Nope, nice and tight. Hoses are in good shape, don't see any pinching going on in the turns. I do have low profile tires, maybe that would be enough to cause the skidding. Still doesn't explain why the pedal goes almost full stroke.
Old Dec 16, 2015
How about.....If you sloooowly push the pedal down does it go to the floor?
And if you stab the pedal quick the brakes feel normal?
Old Dec 16, 2015
I'll try that tomorrow
mikebj23
Jul 28, 2015 08:08 PM
BootyDo
Jul 26, 2015 10:38 AM
duyaknow
Nov 23, 2001 07:28 PM
Sparty
Nov 15, 2001 04:55 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
