95 Civic EX Idle Issue
Yesterday I got off of the interstate and when I got stopped I noticed that it was still idling too high. I dropped it into neutral and it was running at 2 grand. If i revved it up it still wouldn't drop back down. If I got under the hood I could push the throttle down and it would drop to proper idle and could be revved up then and drop back down properly. However put it in gear again and give it gas and the idle goes up and stays.
Only mod done is cold air intake that has been on for almost a year. I have pulled the IAC and used carb/injector cleaner to clean dirty screen and problem still persists. The only code being thrown is 41, which I have been told wouldn't affect the idle in such a way. Any help/suggestions would be greatly appreciated.
Re: 95 Civic EX Idle Issue
Sounds like your throttle is getting stuck plus you might have hurt ur civic alil more than help with the intake, unless you have an exhaust system with, it's like a human we need to release just as much air as we suck in
Cable adjusted too tight, cruise cable problem, cables misrouted, carpet laying on the gas pedal, something along those lines.
Again the intake has been on there for almost a year now with no issues. I have checked to make sure the carpet isn't catching it also. This was only happening if it was put in gear and given gas, if left in park or neutral it was fine. I removed the IAC again last night and let carb cleaner sit in it for a bit this time and then let it dry for a good hour before putting it back on. Today the problem is still there, but is now all the time and at one point started to do a high-low fluctuate.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
