Brake Lights
Brake Lights
So I just bought a 93 civic HB DX. The problem is that when all 3 brake lights are plugged in it blows the fuse. Works just fine if it is the left and middel light or the right and middle light. When i have a bulb in all 3 the fuse blows. Any thoughts? Thinking it is a bad ground wire. Any help??
Re: Brake Lights
that's wierd....if 2 bulbs are in the fuse doesn't blow? Do you know what type of bulbs they are? I just did a quick google for 1157 bulbs but I'm not sure if that's what they would be...
http://www.run-n-lites.com/bulbspec.asp
but 1157's only draw 2.1 amps each so 3 should be well below the fuse rating. Something else wired into that circut? Any aftermarket wiring in the car? Like a car stereo/amp? Alarm?
I was thinking 'short' the first time I read that but it sounds more like you're exceeding the fuse rating for some reason.
Re: Brake Lights
Uhhh
Trailer light adapter?
See if maybe the front park lights are coming on when you step on the brake, that would probably mean the wrong bulb(s) are in the brake lights.
Re: Brake Lights
It has a trunk lid with the light. After market electrical stuff is just a rpm gauge idk about the wiring. And I'm an going look at the bulbs and fuses this afternoon and check the ground wiring. Thanks for the help. I'll let everyone know if any of this works.
Re: Brake Lights
So I took a look at the fuses and wiring and put a new fuse(20) in. There is a RPM gauge that is after market but I couldn't tell if it was wired into the brake lights. I would think not because of location and it needing constant power. Just my thinking correct me if I'm wrong. Also replaced the bulbs forget the size of hand but went to Auto Zone and had them pull up the size on the computer. Right now everything seems to be working fine. Thanks for the help. If it happens again I think I am going to take it to a shop so they can take a look at the wiring.
Re: Brake Lights
Well i am going be taking my car to the shop to have them look at the problem. My state requires inspections and mine is up soon so i have to get it taken care of. I had everything working fine and now it is doing the same thing. i put brand new bulbs in and fuses and when i hit the brakes it burns out the bulb. The fuse size is 10 for the brake lights and is still good it just keeps burning the bulbs. I dont what else it could be. If anyone has any tips on wiring or the such any help is great.
MamaBear2015
May 27, 2015 12:04 PM
trellex
May 24, 2015 04:39 PM
Ma213802
May 18, 2015 07:01 AM
