- '92 Civic Si - Cranks over, but won't start intermittently
- Hood latch issue
- new to honda.
- Bent Driver side axle shaft. Need info
- timing off need help
- map sensor problem need help plz
- 94 civic coupe w/99 b18b1
- Where is the Fuel Pump Relay 96 civic EX
- Grinding noise when downshifting or letting off gas
- rear trans mount removal
- 93 civic ex speedo problem
- Not getting the best gas mileage and wondering why
- bonnet/front bumper
- Oil is leaking fast from a valve or regulator right behind valve cover
- broke the temp control slider
- Creaking noise when turning the steering wheel
- Valves bent or just stuck?
- 88 Hatch No Blower... Frustration!!!
- 92 hatchback D16
- Smoking
- Problems with my d15b7
- obd 1 code
- wont start
- Headlight issue
- 1995 Civic DX: Surging idle will not go!
- Engine Chocking???
- 90 CIVIC Temp gage
- fuel delivery problem need help now
- Heating Nightmare
- Cruise control problem 1992 LX
- **NEED HELP** 1994 civic D15 misfire
- No ch-ch-ch-ch when starting
- 1989 Civic hatch Main relay ?
- blinker problem
- still with the idle surge
- 1995 Honda EX - Car begins to shake when in first gear
- ECU code 2?
- 1993 Civic DX Oil Question
- 95 Civic misfires- Sometimes on cylinder 1, sometimes on 3. Stumped-Any ideas?
- 1992 civic keeps failing etest!!!
- 93 civic new radiator&therm still overheating
- 1995 civic ex vtec. overheating please help
- 1995 civic idle problems
- can the idle be adjusted on a 1991 civic lx?
- 94 Honda Civic steering problem
- very simple question
- 99 Civic EX won't start. Just replaced heater hoses.
- Still getting a code 16 after new injectors installed, WTF??
- car gets warn then shuts off...help 93 civic ex
- Spark Plug Ultra-Stuck, Considering Options
- Urgent 1994 civic problem - wont start
- Over Heating when slowing down - Advice Needed and Very Appreciated
- 91 civic mpfi wiring
- 1993 DX ignition problem
- Wire Set removed, now a couple of them won't fit back on spark plugs
- fuel injector install suggestions
- New here have exhaust question
- I need help with removing a fuel filter from a 1991 civic lx
- replaced lower timing cover -now will not start
- 93 Civic Vei electrical problem
- Rear defogger power clips
- 94 Civic EX tranny delays shifting
- d16z6 swap in 89 hatch
- Getting a code 16, so what should the next step be??
- Hood cable broken, can't open hood!
- DRIVE SHAFT PROBLEMS> pOpING nOisE
- 94 Civic DX - Starting Problem
- 92 Civic dx starting problem. HELP!!
- 1993 D15B7 Head Gasket replacement
- Greetings, Question.
- 1995 civic exhaust questions.
- rough idle, no power
- stuck crank bolt
- fuel injector electrical connector
- Erratic idle, minimal power, code 41 (O2 sensor) but replaced and same code
- '91 Wagon Does Not Start Sometimes, Stalls
- 94 honda civic cx hard to start hot or cold
- 1991 civic dx 4 door, checking clutch fluid ?
- bar's leak head gasket seal professional
- 90 civic DX
- front end squeaks
- 94 EX misses when engine warm, badly when weather is hot
- New to Honda's Need Direction
- '88 engine will turn but won't start
- New Owner of a 95, quick tranny question
- Radiator and radiator cap help
- 92 civic 4 dr sedan
- spark plug tube orings
- please help, car idles hard and loses power
- Rear driver side door wont open
- 91 civic coolant line
- 94 Civic DX starting problem
- 93 Civic ex problems...HELLLLPPPP
- weird noise at start up and steam out the gas tank
- 1995 civic ex sedan (need help))
- 91 Civc SI: Q&A
- 1986 3dr DX Carburetor Base Plate
- car pulls hard when accelerating
- 1989 Honda Civic DX
- 95 Civic has several problems.. i need some help
- bogging at low rpm's
- Suspension-question
- 93 Honda civic problem
- Honda Ballade/Civic engine wont start
- 1999 Civic Air Conditioner Troubleshoot
- 94 dx fuel pump working intermittently, please help
- hard to get my car into gear sometimes
- 1990 civic DX idle issue
- idles up and down but it all started with antifreeze?
- D16Z6 Number 1 Fuel injector leaking AGAIN!
- need help - fiance's lexus overheating.
- Just wondering...
- Fuel Mixture, Black Smoke - Honda 93 Civic computer controlled carby
- Front End!
- Missing timing alignment mark
- Need Help - Replace 1993 Civic DX ECT Sensor
- 95 AC Cool But Not Cold
- Oil in Spark Plug Tube
- 91 civic with d15b7 need help asap!
- starter issues
- car wont shut off please help
- Fuel Tank Leaks
- BAD misfire and stutter
- AC Idler Pulley Question 95 EX
- Need advice on my 92 si hatch
- Need help, do not know if i have the original engine
- IACV/Idle advice 95 civic
- Engine overheats/Fans not working?
- Coolant Leak
- Water leaking inside car!
- setting timing on 1.5l
- right front brake draging after brake job
- '92 VX Idle Too Low
- Oil on Spark Plug
- 2001 civic evap soleniod valve
- first civic, what to look for?
- speedometer problem 95 civic
- 4th gen civic/crx's
- dpfi to mpfi issues
- d16z6 Number 1 Fuel Injector leaking.
- fan doesnt stay on
- camber kit
- Need 1993 Civic PGM-FI Relay
- Traces On ECU Modified?
- 87 Civic won't stay running, while cold
- High Idle when warm
- right turn signal
- Just acquired a 94 Civic LX
- Lost ignition chip
- '91 Civic engine troubles
- break and reverse lights are out on passanger side
- rev-limiter
- 1993 Civic DX Continued Stalling Problems--Need Some Help?
- Strut tower housing cracks. Fixable?
- Auto trany problem
- i need some serious answers
- i need someone that knows what about camber
- Decomposing animal smell....help!
- 94 Honda Civic EX cranks but quickly dies
- Charging issue 95 DX
- P28 auto no R18 rsistor?
- 93 Civic DX engine idling up and down with AC on
- 83 civic Tbelt broke!! How do i check the valves?
- Starter sometimes keeps spinning once car starts (and other starting issues)
- 83 civic No spark?? Any Ideas?
- 95 Civic Ex CEL (41) = much conflicting information re: O2 sensor
- power issue, seemseasy... its not
- Need to replace hood\fender
- overheating issues
- door window interchangeable?
- 95 civic dx with odd gearing....
- ignition/ steering wheel locked
- 93 ex no spark no fuel need help asap.....please!!!!
- gauge cluster lights
- 1993 Civic DX Starting/Stalling Problem
- A/C Issue tired of wasting money
- 93 civic started running rough, guzzles fuel
- Stranded on road trip. Need tips on replacing Water Outlet.
- 95 Civic DX halfshaft
- Check engine light
- d16y8 idling at zero? lol help
- 94 Engine just stopped
- tire rub and rear breaks
- batter light n speedo problem
- 92 civic engine light check need help
- 87 civic si pgmfi light on, no acceleration
- exhaust help
- Purchasing 95 Civic DX
- Speedometer 5 mph off - 87
- 1991 Civic DX problems
- 93 honda civic DX
- wow the whole underside of my 87 is rotted
- 94 Civic A/C stalls engine
- car wont go over 180
- No acceleration power. Help!
- newbie...anyone wanna give me tips on clutch replacement? 87 si
- 89 Honda Civic, Code 1,4,12
- Which oxygen sensor to buy for '94 VX?
- Question? i need help
- 91 Civic DX one of the two radiator fans doesn't work! AC not cold when stopped
- 95 SI hatchy, speedometer issue.please help!!
- 1993 Civic DX Surging Issue please help
- Idle too low
- 92 1.5 Civic Idling from 1000 to 3000 constantly???
- Too much oil
- '95 Civic EX coupe/ D16Z6
- is it my piston rings?
- Fuel Pressure Question
- '92 Civic DX Cooling Problems
- 87 Civic front end squeaks
- Will a S20 A000 trans bolt in place of a S20 B000?
- 91 Civic wiring issues
- Can't remove front LCA bolt
- 5 speed 1995 Civic. Clutch sometimes falls.
- Different Seats?
- 93 civic idel issue
- '95 _ gas smell
- Idle problem
- Locate ECT sensor 1992 VX
- Torque specs for 5th gen honda civic?
- block sealer?
- 95 civic DX 1.5 non-vtech hard starting after engine is hot.
- overheating n high to low idle
- Civic lx 89 d15b2 1.5 stalled when slowing down wont start
- No compression in # 3 Cylinder
- Window Tint Removal
- 1995 Civic Turbo Issues
- 93 ex hard start
- 94 Civic DX dash problems
- 92 Civic DX overheating
- Overheating and revving up and down.
- I hydrolocked my engine and fixed that part. now something eletrical?
- 1990 Civic with minor oil leak
- d15b1 DPFI help! running & idling problems!
- REBUILT D15b7 WONT START!!!
- 92 and 95 civic water problems
- 94 Civic EX...issues :(
- Transmission issues? Heavy pedal.
- 94 si d16 clutch/tranny issues
- 93 HONDA CIVIC DX Problem
- 93 - No Crank (no start)
- 92 Si no power to starter or fuel pump
- first honda and need help
- 94 ex coup tranny problems
- 95 civic EX Timing issue? Grinding noise?
- 91 dx starts but doesn't idle.
- spark
- 91 Civic B16 swap....help!!!
- 92 civic lx auto tranny shifting problems plz help
- 95 si hatch wont stay on
