still with the idle surge
Old Oct 24, 2011
95civic123's Avatar
95civic123 is an unknown quantity at this point
Ok I replaced the sparkplugs, air filter, cleaned the iacv valve, put on a new tps sensor, set the idle, and did the idle learn procedure. My 1995 civic vx still has the idle surging and a studder at the pedal. Does anyone have any other ideas it also does not have a ftiv valve. I'm stumped
Old Oct 24, 2011
Re: still with the idle surge
might have a vacuum leak.
Old Oct 24, 2011
tildeath's Avatar
tildeath is an unknown quantity at this point
Reset the ecu. I had to when i repalced i Iacv the ecu was saying it was still bad.. Reset the ecu and Bam no code. Pull the postive off the battery for 10 seconds and see what that does..
Old Oct 24, 2011
95civic123's Avatar
it has no vacuum leak i checked that and i rest the ecu when i did the idle learn idk is there a way to tell if my iacv is bad
Old Oct 31, 2011
tdbaker156's Avatar
tdbaker156 is an unknown quantity at this point
try tightening your throttle cable a little bit. you should be able to smooth it out that way. its worked numerous times for me. as longas your sensors are good.
Old Oct 31, 2011
tdbaker156's Avatar
also check your pcv valve for leaks.
Old Nov 3, 2011
Ericjergs's Avatar
Ericjergs is an unknown quantity at this point
I'm pretty sure to check if your IACV is bad, you have to take off your intake to the throttle body and plug the little hole inside the TB(the one closest to where the IACV is) and if your car idles fine then your IACV is probably bad.
I know you checked for vacuum leaks, but just in case, while you have the intake off, put your hand over the throttle body opening. If the car DOESN'T die, then you may have a vacuum leak because of the TB gasket.
Anyone feel free to correct me if I'm wrong.
RSKtakR
25
Sep 14, 2015 07:43 PM
pfwel1977
Sep 10, 2015 02:16 PM
Bricoleur
Sep 9, 2015 12:23 PM
thaler4cuse
Sep 7, 2015 08:25 PM
