Headlight issue
Old Nov 3, 2011
ayago's Avatar
ayago is an unknown quantity at this point
Headlight issue
I recently have noticed a problem with my 94 CX. I'll be driving at night and have my headlights on, I'll switch to the high beams, and then when I try to switch back down to low beams, the switch makes it's clock noise and the lights go out... if I stop and monkey around with the switch and pull the fuses (which are all good) the low beams will come back on. Any ideas of where to look?
Old Nov 3, 2011
Ericjergs's Avatar
Ericjergs is an unknown quantity at this point
Re: Headlight issue
I kind of had a similar problem with my 85 Monte Carlo, my back lights were all screwy, for instance my left blinker wouldn't work, but if I used the hazard lights both blinkers would come on. Anyway, to fix I took out the bulbs and cleaned the contacts and the socket they went in to. There was some gooey build up on it, that didn't really look like the stuff they put in there to stop corrosion and what not.
Not saying it will work, but it might fix your problem, and it isn't really a hastle to do.
Old Nov 4, 2011
Seby05's Avatar
Seby05 has a spectacular aura aboutSeby05 has a spectacular aura aboutSeby05 has a spectacular aura about
Re: Headlight issue
It might be that the contacts on the switch are all wore out an loose, and it doesn't make contact anymore when u switch baxk. Either that or some relay. Are your low and highs on the same bulb? If there are different bulbs for low and high beams, when you go to high, are the low beams supposed to go off or do they run together?
Old Nov 4, 2011
Re: Headlight issue
might just be a bad switch. they do loosen up over time
stryder12
Jun 30, 2015 08:33 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
civic_gt
Apr 19, 2015 08:15 AM
