1991 Civic DX problems
Old May 26, 2011
jboyce's Avatar
jboyce is an unknown quantity at this point
I have a 1991 Civic dx hatchback, just recently rebuilt the head of the D15. Current problems i have are : Engine smokes really bad when i start it. Engine sputters through the bottom range of rpm's, then jumps back to normal. Temperature gauge does not work now. The engine also pops while idling.
We adjusted the timing according to the manual and the hood sticker. the manual says to adjust it to the color notch that is specified on the hood, but the hood sticker says the timing should be set to 18 degrees, not sure which color is 18 degrees.
We think the temperature sending unit was damaged during the milling of the head, since we forgot to pull it out. We also are hoping its something simple as a vacuum leak and not something more catastrophic.
any help would be great, thanks!
Old Jun 4, 2011
lazlong's Avatar
Re: 1991 Civic DX problems
Is it throwing any codes? http://check-engine-light-codes.blog...retrieval.html
Old Jun 9, 2011
HeXaZ's Avatar
HeXaZ is an unknown quantity at this point
the weird idling and rpm fluctuation sounds like the IAC valve to me. Better get it checked out. The smoking you can expect. You did just rebuild the engine so give it some time to break in.
Old Jun 26, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
and after the motor breaks in and it still does it then it could be the valve seats i had the same problem with my toyota and the temp guage problem is probably the temp sensor
Xuhme
21
Aug 7, 2023 03:40 PM
Rinzlor
Apr 24, 2015 10:33 AM
Braun
Apr 23, 2015 09:03 PM
dooner24
Apr 14, 2015 07:51 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
